Old 12-08-2019, 10:29 AM
vernon smith's Avatar
vernon smith vernon smith is offline
Default Large baffle leak
The picture below is the baffle at the rear of the engine with the top motor mount protruding through it. I'm looking for an easy effective way to plug up/cover this huge pressure leak.
Old 12-08-2019, 10:31 AM
You can mold or buy a fiberglass cup which mounts to the baffles and covers the hole. Alternately, you can take a piece of baffle fabric and make a baffle to seal the opening.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 12-08-2019, 10:43 AM
aturner's Avatar
aturner aturner is offline
If you are careful, you can seal it with RTV on the backside.
-Andy Turner
RV-10 N784JC
Old 12-08-2019, 11:48 AM
9GT's Avatar
9GT 9GT is offline
I just made some nice looking fiberglass covers for mine using 8 oz disposable food containers as plugs. The kind you get at the deli for stuff. Someone does make and sell them though.
David C.
Howell, MI
RV-10: #41686 Under Construction
RV-9A: #90949 Under Construction
RV-10: #40637 Completed/Sold 2016
Cozy MKIV:#656 Completed/Sold 2007
"Donor Exempt" but donated through Dec. 2020
Old 12-08-2019, 11:56 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Aerosport has them ready made if you don't want to DIY fiberglas...
http://www.aerosportproducts.com/pro...-mount-covers/
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-08-2019, 12:54 PM
Thanks, I'll order a pair.
Old 12-08-2019, 02:22 PM
Pdtofly Pdtofly is offline
Default Hole plugs
http://rvbits.mybigcommerce.com/prod...T-COVERS..html
$40 for the set plus $15 fixed shipping from So Africa.
They will work on anyplane, not just RV-10?s.
Brian
Old 12-08-2019, 02:34 PM
RV10Pilot RV10Pilot is offline
I made my own out of fiberglass. Use a greek yogurt single serve container and clay to make the form.
Old 12-08-2019, 03:39 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
A piece of aluminum or stainless steel tape will work just fine. Just pull off annually for inspection and reapply.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 12-08-2019, 07:23 PM
Paddy's Avatar
Paddy Paddy is offline
Default Engine Mount Covers
I hammered a pair of covers out of some 3003 half-hard sheet. Annealed twice during the work if I remember.
RV-10 N415JS
Slow build kit #40874
Homebuilt Kit Champion Oshkosh 2019
Atlantic crossings: 2
