Old 12-05-2019, 05:41 AM
design4p design4p is offline
Default Garmin G3X alerts
I will be installing Garmin G3X displays together with a host of Garmin items.
Can the Garmin G3X system be programmed to have verbal and visual alerts.
John
Old 12-05-2019, 06:00 AM
bjdecker's Avatar
bjdecker bjdecker is offline
Default CAS
The G3X Touch (GDU46x) can have an audio alert in conjunction with a visual cue for parameters as well as general purpose inputs (canopy open, alternator, etc.)
Configuring the parameter as "yellow+alert" or "red+alert" will cause the message to flash and a >bong< to sound.
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 12-05-2019, 07:21 AM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Verbal alerts are fashionable, but... They're best used when immediate maneuvering is required (traffic, wind shear, terrain) but inappropriate for systems (pressures, temperatures, voltages). The systems warnings want don't require you to drop what you're doing and handle the problem right now -- they can wait a few seconds. And verbal alerts aren't good for stall warnings, either, as it takes too long to say the words, and for other reasons.
Ed
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 12-05-2019, 07:29 AM
KeithB's Avatar
KeithB KeithB is offline
Garmin documentation recommends the audit out (tones and verbal) be connected to an "always on" audio channel. However, based on input from VAF posters, I used an "Aux" audio channel on my audio panel allowing me to selectively silence the alarms. It turns out to be a valuable bit of flexibility. Flying in to Johnson Creek, poor "bitchin' Betty" was beside herself with "Terrain, terrain" and "Traffiic, traffic" (I was following a lead aircraft) and her frantic help was a severe distraction, until silenced with a single button.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, 24th in the air, >600 hrs
XP-400 Aero Sport Power, replaced with Lyc Thunderbolt 390
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 9/2019
Old 12-05-2019, 09:32 AM
JDA_BTR JDA_BTR is offline
I got all the annoying terrain alerts in a left pattern at Hot Springs Arkansas. Not a typical place for it. You have a good idea here.
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 12-05-2019, 09:54 AM
jliltd jliltd is online now
I hardly ever allow any kind of bichin' betty alerts. I think they are distracting to the point of causing a safety issue. It seems every avionic designer thinks his function is the most important thing in the panel (fixed or portable device) and insists his alerting be attached to unswitched audio. And the FAA goes along with it. And if left un-abated the hapless pilot starts to become desensitized to the system "always crying wolf" which is a safety issue on the opposite side of distraction.
If I wanted all that while flying I would bring along the ex wife.
Jim
RV-8
(a few more airplanes too)
Old 12-05-2019, 10:07 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Default G3X Touch Alerts
John
John,
The G3X Touch system has a number of different methods for alerting the pilot to different sets of triggers.
As Brian mentioned, you can program the Engine/Airframe Input’s to provide both aural (tone) and visual alerting when a certain threshold is met, by using the Red Range + Alert Gauge Marking. The procedure for programming this is on page 35-159 of the AL Revision of the G3X Touch Installation Manual. You can download the Installation manual from this web address: https://support.garmin.com/en-US/?pa...00&tab=manuals
There are also other alerts the system will issue relating to things like traffic, terrain, obstacles, minimums, autopilot, altitude, and descent rate. There are custom settings and configurations for most of these. The Pilot’s Guide is a good resource for understanding how and when the various alerts will be triggered. It can be downloaded from the same link provided above.
Please let us know if you have any other questions. You can email us at G3Xpert@Garmin.com, or give us a call at 1-866-854-8433 Monday – Friday, 8:00 – 5:00 CT.
Justin
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 12-05-2019, 10:47 AM
Default Hmmm
?...I think they are distracting to the pojnt of causing a safety issue...?
Really?
So we should do away with:
Traffic, traffic
Pull up
Wind shear
Obstacle
Fire bells
Airspeed low
Etc?
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 12-05-2019, 12:42 PM
dutchroll dutchroll is offline
Really?
Yeah having flown professionally in aircraft with aural alerting systems for a long time (20 years), I found that puzzling too. Part of the reason things like GPWS aural alerts were invented was due to the number of aircraft permanently parked on the sides of mountains. Similar principle for stall alerts, TCAS, etc.
The real danger is using them but ignoring them. I can see isolated & specific cases where you might want to suppress certain alerts but overall they?re certainly not a retrograde safety step.
Mike
Down Under
Old 12-05-2019, 01:55 PM
Default Yes
Yes, they are there FOR safety reasons...and ignoring them can be hazardous to your health...
Bob
297 HP Barrett Hung
Wiring...
