While in the process of preparing the tanks for sealing I have had time to research the best application of tank sealant and lessons learned from other builders along the way. I wanted to have the best product that I can build and so I decided to make up a couple of samples using both standard "spring back dimple dies" and tank dies. I learned that tank dies make the hole .005" deeper to accomidate the sealant under the rivet head. The first sample was two sheets of .025 using standard dies. I wanted to try the fay sealing method that has been discussed about here at length. I was able to get the flange to set flush and create fillets and fully encapsulate the shop head of the rivets. I made two more samples using .032 skin side and .025 flange side, one with tank dies, and one with standard dies. After fay sealing and letting tack up for a day or so, I wet installed the rivets and set them with a squeezer.
When I was finished I found that setting the rivets with the tank dies was slightly more cumbersome and hard to get the rivet to stay in one position while being set. It seemed to wallow around a bit and the shop head was hard to set without cleeting over slightly. I assume that the sealant acted as a bit of a lubricant. The skin side had a noticable recessed area or dimple around the manufactured head of the rivet. Several of the rivets stuck up at an angle. Not bad but noticable. The rivets set using the standard dies were less difficult to work with and seemed to lay down better with no noticable dimple or recess. I can only assume that the rivets set using the tank dies had more sealant under their head as opposed to the ones using the standard dies.
I plan on fully encapsulating the shop head of the rivets so as to preclude leaks at that point. My final conclusion was that I plan on going ahead with standard spring back dimple dies for all 3/32 rivets. Here are some pictures.
First sample.
Tank dies. Notice the dimples or recessed area around the rivet head
Standard dies. The rivet head lays flat in the dimple
I suppose that using either standard or tank dimple dies will produce a good leak free product, but I tend to like the appearance using standard dies.
First sample.
