Microkit Solutions/ Engine Bridge
I have one installed on an IO-390, with analog inputs to a Garmin GEA24 and G3X. I’m able to monitor timing and temps on both PMags (though the PMag temp output is less than accurate) right on an lEngine” tab on the G3X. Timing is changed by a WiFi interface to either my iPhone or iPad. Works as advertised. Install was easy - biggest problem was adding new wires to an installed panel and I used it as an opportunity to improve my Pmag wiring.
