Differential Pressure Test Kit
Thanks Dan. I need something to test both my Continental A65 and my some-day-to-come Lycoming. I think I have a handle on it now.
I believe you need different testers for A65 and the Lycoming. They have a different size orifice for different displacement.
No, they don't.
The gauge orifice for small engines has specified diameter of 0.040”
and an entrance angle between 59 and 60 degrees. You’ll find references
requiring a 0.060” orifice for use with a bore diameter larger than
5 inches. However, a manufacturer’s service information takes priority
over any advisory material. Lycoming SI 1191A and Continental SB 03-3
specify the 0.040” orifice for all engine models, including those with
bores in excess of 5 inches
No, they don't.
The gauge orifice for small engines has specified diameter of 0.040?
and an entrance angle between 59 and 60 degrees. You?ll find references
requiring a 0.060? orifice for use with a bore diameter larger than
5 inches. However, a manufacturer?s service information takes priority
specify the 0.040? orifice for all engine models, including those with
Interesting.
So all of us out here that are using the E2A-1000 tester that ACS says is for cylinders of 5.00 inch bore and over are getting erroneously high readings?
The incorrect reading would only be during the calibrated orifice test conducted before the actual differential pressure tests on the cylinders. This test is to determine the lowest acceptable reading for today's compression test and won't affect the cylinder test. You might be surprised how low a compression reading this test will show as being acceptable.
Ed Holyoke
Comparison with the "calibrated" leakage orifice is a Continental standard, not Lycoming. And no, I am not surprised.
Perhaps it would be best to read the appropriate manufacturer's guidance?
Postscript:
Let's make this easy. Per the OP's question, choose either below, the difference being the T-handle extension, which offers hand tightening. Both are 0.040" testers for flat Lycoming and Continental. Compare the cylinder reading with the test orifice reading for Continental. Ignore the test orifice for Lycoming. In either case, interpret results per Continental SB 03-3 or Lycoming SI 1191A.
https://aircraft-tool.com/shop/detail.aspx?id=2EM
https://aircraft-tool.com/shop/detail.aspx?id=2EM-KIT
These are ATS brand tools. Precise accord with Continental SB 03-3 would require purchasing the equivalent tool made by Eastern
Ed Holyoke
Is this really a compression test?
A proper compression test would be accomplished with an automotive type compression gauge screwed into the spark plug hole and measures the compressed volume of air that is pulled through the intake valve based on cam lobe shape, and held by the rings and valves.
A leak down test will not show you a failed cam. But it will show you where the leak is. Both are worth doing.
A leak down test will not show you a failed cam. But does show you where the leak is. Both are worth doing.
You're correct, this is a differential pressure test and not a test of how much pressure you can build in the cylinder by piston movement. We're measuring leakage. The source of leakage could be rings or valves. The Continental Service Bulletin Dan referenced gives all the info you need to conduct and interpret the test. Just because it's the standard test specified by the engine manufacturer and by AC 43.13 doesn't mean that it is definitive or tells you every thing there is to know about the condition of the cylinder. The SB does require you to do a borescope inspection and shows pictures of poor conditions. This guidance only applies to Continental engines and, some would argue, only on a certificated airplane. It's still pretty good advice for other engines. Continental tested engines with very low compressions and found them capable of making rated power, though oil consumption was pretty high, and that's what they based the calibrated orifice data and test procedure on. It always used to be, that if you saw less than 60/80 on compression test, the cylinder was coming off. Even Lycoming no longer requires that, though they do still suggest the 75% of input pressure standard.
Ed Holyoke
