Pitot tube and stall warning wire
Looks like both should pass through the ribs on the LEFT wing, aft of the fuel tank. However, there is only one set of holes for the snap bushings. Do I drill a second set of 7/16 holes in the left wing ribs? Or does one of them go in the right wing?
It doesn't matter which wing the stall warner is on; mine is on the left with the pitot tube. For the wire, I routed it aft of the spar and put it into the conduit for the rest of the wing wiring; you'll have some sort of run from the root to the tip for lighting. The conduit did need some extra holes in the ribs to run it up and down the wing.
More detail from the mother ship is here:
https://www.vansaircraft.com/faq-technical-builder-items/wing-wiring-routing-wires-in-the-wings/
