Old 01-12-2019, 12:14 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Originally Posted by airguy View Post
Ross - for a non-owner of CPI trying to make the decision about model choice, can you give a quick rundown of the delta between CPI and CPI2 for functionality? What are the differences that would lead to a choice between them?
The CPI2 has better over voltage protection, backup battery solution with auto switchover and warning, more programmable settings, serial output for data logging is available.
With the remote mounted controllers, the panel space for the programmer is much reduced, especially when dual controllers are used. (single programmer can talk to dual controllers). The panel LCD is larger (12 X 2 characters).
Downsides are costs are substantially higher but still in line with other EI choices which aren't easily user programmable and have less capability. Weight and total volume is higher on the CPI2.
As I said previously, we plan to produce both since there is still good demand for the CPI as it's light, compact, capable and relatively inexpensive. Not everyone wants or needs all the new features in the CPI2.
I started on a new CPI2 webpage 3 weeks ago which will outline all the new capabilities and but don't want to upload it until all testing of the production parts are completed successfully. I don't subscribe to releasing glowing reviews of vaporware before the product exists and has substantial testing behind it. This thread covered some of the difficulties faced during development and the solutions found. We don't sugar coat things- this was a very challenging product to develop.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 439.3 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 01-12-2019, 01:07 PM
Toobuilder's Avatar
Glad you're sticking with both products... The original CPI is an outstanding system, forgetting for a moment its the lowest price EI option out there.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 01-14-2019, 10:39 AM
rdrcrmatt rdrcrmatt is offline
How do I get added to the waiting list?
I'm not sure about a single or dual setup, but I most certainly want a CPI-2 system.
Matt
CFI / RV-10
Old 01-14-2019, 12:11 PM
rv6ejguy's Avatar
If you drop me an email, which you can find by clicking on either signature link, I'll add you on.
Thank you!
Old 01-14-2019, 05:59 PM
rv6ejguy's Avatar
Default Thermal Imaging Tests
We completed the IR imaging tests on the production CPI-2 board today and all concerns from the prototype boards have be rectified. Nothing gets over 50C.
Controller running coils at 6000 rpm. The thru hole regulator is now heat sunk to the chassis and runs nice and cool as opposed to the SMT component we first tried.
6 cylinder coil pack running at 6000 rpm. Center of coil pack and spark plugs (upper part of photo) show the highest temps.
This one was just for fun
We ran the system up to 11,000 rpm for 20 minutes. This is about the limit for things staying adequately cool. Nothing even gets warm at 2700 rpm. Barry added back a bunch of ozone to the atmosphere with all this bench running...
We are adding a few more features in software now which we thought would be nice. Engine tests will be coming soon.
Old 01-18-2019, 05:32 PM
rv6ejguy's Avatar
This photo shows the CPI-2 programmer in gauge mode with the fault light illuminated, LOP mode activated (adding timing to bring peak cylinder pressure to the optimal point with the slower burning mixture), running off the main battery source and programmer is accessing controller 'A' CPU.
The weather turned cold and snowy this week meaning we couldn't run the system on our test engine so Barry cleaned up and tested the data logging software instead. This will log data to a laptop or Windows tablet for diagnostics or tuning. He also did some final testing on the OV protection features.
We had our contractor girl working on programmers and controller boards this week and we've inventoried coils, drivers, sensors, connectors, CNC'd parts and other bits to build complete kits for those on our waiting list.
Old 01-18-2019, 09:35 PM
rv6ejguy's Avatar
Default Data Logging
Here's a shot of the data logging screen in the gauge mode.
You can save and print your ignition maps from here too.
Old 01-31-2019, 08:38 PM
rv6ejguy's Avatar
Default Engine Runs
Our warm (0C) weather is coming to an end tomorrow so we wanted to get some engine testing in today. Still mighty brisk standing in the prop blast for very long. Frozen to the marrow but happy with the results.
The O-200 started right up with an EM-5 doing the fueling and dual CPI-2 running both sets of plugs. We did some noise testing and switched battery sources plus ran through all the functions. The engine never skipped a beat.
We logged the runs on the PC to look at later inside.
Short clip here: https://www.youtube.com/watch?v=ykeN...ature=youtu.be
Old 02-12-2019, 10:57 AM
leok leok is offline
Any new updates on the start of shipping of CPI2?
Last I saw was mid February
Building started Oct 5th 2014, Flying since 1/16/2020
http://www.mykitlog.com/leok
RV Hotel, come by and visit if you're in town
Dues paid 2020
Old 02-12-2019, 12:05 PM
rv6ejguy's Avatar
We've been rather busy with other sales so far this year which keeps impacting the for sale date of the CPI-2 unfortunately. Production hardware is sitting on the bench here but the documentation isn't finished yet.
All initial production is spoken for so it's looking like new orders on the 2nd production batch won't happen until late March at the earliest.
We are shipping FWF components to some customers starting this week so they can continue with the build process.
