Old 04-18-2019, 01:21 PM
moosepileit moosepileit is offline
Originally Posted by donaziza View Post
Drift to the longer-term test thread, I think I have a solution for the uAvionix UATs.
OK, Please tell the solution, as I'm probably getting an uAvionix.
http://www.vansairforce.com/communit....php?p=1339819
RV-6, bought from builder.
O-320, slider, carb, mags, FP
Old 04-18-2019, 01:22 PM
[quote=donaziza;1340373]Drift to the longer-term test thread, I think I have a solution for the uAvionix UATs.
Last edited by moosepileit : 04-18-2019 at 01:22 PM. Reason: http://www.vansairforce.com/community/showpost.php?p=1339819&postcount=183
Old 04-18-2019, 01:23 PM
Only if transponder puts out replies, not just set to 1200, will the uAvionix Beacons be able to act anonymous.
http://www.vansairforce.com/communit...&postcount=183
Old 04-18-2019, 05:20 PM
rcarsey rcarsey is offline
Originally Posted by Driftdown View Post
Does anybody know the status of the lawsuit Garmin brought against uAvionix for patent infringement?
The short of it is that Garmin is ready to go to court yesterday. uAvionix is happy with the February 2020 bench trail date. The court agreed to keeping the original schedule. uAvionix does not seem to want to engage with Garmin to explain how their product does not infringe.. seems like a long road ahead. If you have to choose between their two products...I don't know.. They are both sub-$2000, but there's a chance skyBeacon won't be on the market one day. Garmin had their patent before uAvionix.
(Here) is the latest joint status statement from a couple weeks ago (4 pages).
And the original complaint by Garmin here (112 pages)
Old 04-18-2019, 07:46 PM
Driftdown Driftdown is offline
Very helpful post.
Thank you.
Old 04-26-2019, 07:20 PM
jliltd jliltd is offline
Originally Posted by Low Pass View Post
The FAA still sees and knows who you are. This just shields your N-number from the dirty masses. Any shenanigans done while your system is on, stay online somewhere, in an ultrasecure FAA server - forever.
For those like me who have been studying, following and using "anonymous mode" for 5 years I say your statement is conjecture at best. I have experience with FreeFlight Rangr, Garmin GDL 88, Garmin GDL 82 and Uavionix UAT products under anonymous mode with the randomized ICAO code. I have talked at extent to regulators and avionics manufacturers. UAT anonymous is truly anonymous. Where did you get your information?
Jim
RV-8
RV-3B
Old 04-29-2019, 08:12 PM
Yeah . . . with regards to a specific reference . . . either put up or shut up.
Old 04-29-2019, 08:25 PM
To be truly anonymous you?d have to shield your ICAO hexadecimal code. I don?t think that?s an option.
Old 04-29-2019, 08:32 PM
Steve Iacoviello Steve Iacoviello is offline
When in anonymous mode that is what happens. Your hex code is randomized.
RV-9A completed 12/2011
N579S
Old 04-29-2019, 10:30 PM
This thread prompted me to look at FAR 91.227 out of curiosity. It looks like when you don?t file a flight plan or request ATC services you can Omit your call sign and ICAO code but if you file or request ATC services you have to broadcast your ICAO code. See 91.227(d) (8) and (11).
