Spark plug technology and choices
kaweeka
I added to a prior post about spark plug heat ranges after finding dry fouling on my BR8ES plugs in all cylinders. (Compression is good, 76-78/80) I run an IO 320 B1A with dual LSE Plasma III and AFP injection with 9:1 pistons. I typically fly LOP. Klaus' manual recommends the Denso IK27 which is actually a cooler plug that the NGKs in there now (the 8 heat range corresponds to a 24 in the Denso world). I wrote Klaus but, no surprise, haven't heard back. Using the 27, or even 24 when already noting fouling with the current NGK doesn't add up to me. While looking and reading, I came upon the website for Brisk Racing. There are myriad plug types and one that I am not familiar with called a multi-spark plug.
The description is this: "they produce more than one spark per impulse of the ignition system. More than one simultaneous point of ignition results in better and more spontaneous ignition of the air-fuel mixture. Spark Plug sparks are not shielded by the ground electrode; therefore it provides faster, unrestricted expansion of the flame front. The mixture burns more uniformly and more quickly. The result of better utilization of available combustion energy is more power, better acceleration, lower harmful exhaust emission and reduction in fuel consumption."
It says it is designed for high output ignition systems. Would this be applicable to my set-up? Has anyone used or considered this brand or specific plug before? I do tend to overthink things so I apologize in advance. I am NOT an engineer but want to learn and understand these questions as they arise. It makes me safer and better able to make decisions that are beneficial to my aircraft and flight safety. I appreciate any knowledge from you all.
Thanks and be well everyone,
David
I'd say if you are seeing actual fouling with NGK 8s in there, you are running far too rich or you have an oil consumption issue.
Thousands of aircraft are flying with NGK 8s or Denso 24s and 27s with no fouling issues so your engine seems to be the anomaly here.
I don't see any good reason to consider any other brands or type of plug for a stock Lycoming.
I've been building stock and race engines and working on them for 40 years but never heard of Brisk before and never seen one of their plugs installed in any engine yet they claim to be one of the largest manufacturers of spark plugs in the world. Hmmm. Wonder why Toyota, Subaru, Nissan, Honda, BMW etc. mainly fit NGK or Denso as OE?
There's your snake oil, right there. Spark plugs do not generate multiple sparks per voltage pulse. The voltage will rise on the plug electrodes until you get a dielectric breakdown in one location, the spark forms there and discharges the voltage differential. It's not possible to get more than one spark from a single voltage pulse, even the "split-fire" plugs with two electrodes will either fire from one, or the other.
The only way to get multiple discharges per firing event is from the ignition system itself - the coil and whatever is driving it - not the spark plug. Some ignition systems are capable of putting more than one high-voltage pulse behind another, either the same polarity or opposite but still a high enough voltage to achieve breakdown on the spark plug tip. The spark plug simply reacts to a second voltage rise by generating a second spark - but no plug ever built is capable of making two sparks from one voltage rise.
IO-360 with dual P-Mags, now done 400 plus hours on NGK BR9EIX, which was what Brad suggested. I buy them at O'Reilly's and they price match the best interweb prices.
Change them once a year whether or not, never had an issue.
Sidebar:
A quick reminder to buy the type of spark plugs with solid tips rather than screw-on tips. NGK uses the same model number for both types. It only changes the part number to distinguish the difference between screw-on tip and solid-tip plugs. For the BR9EIX the proper NGK part number is 3089. The wrong part number is 3981. I have found most of the local automotive supply stores stock plugs are the screw-on type. Why NGK would use the same model number for both types boggles the mind.
My first set of NGKs (3981's) had the screw-on tips as I had no idea there were two types. I tightened them and then swaged them in place by indenting with a pair of dull dikes. Then I read here about the solid-tip being the better way to go so ordered a set of 3089 solid tips to swap out next oil change. Last week I did the first oil change on a fresh Barrett overhaul and while swapping out the plugs I discovered 4 out of 8 of them had loose tips. Eeek. That's 20 hours in service since new with staking to lock them in place. I did not expect a 50% loosening rate. Loose screw-on tips can cause arcing issues and missing.
Jim
I like the price of the NGK vs the Denso. The question is, should I use the 8 or 9 heat range with my IO 320 with 9:1?
I am running NGK BR9EIX # 3089 solid tips on my 0320 H2AD with SDS CPI ignition on one side. It is standard with 9:1 CR. No problems noted. It never fouls them and they look good upon removal so the 9 heat range seems good.
Gap for BR9EIX
I was just working on my CI and thought I would try the BR9EIX instead of the BR8EIX. What gap are people running with on these?
Ive got dual Plasma IIIs in my RV10. I?m running the Denso plugs (IK24). Have not had any issues. I generally follow manufacturers guidelines because I figure that is what they used to do their testing with. I dont see the benefit of using something different.
Klaus provides the Denso?s with his system, so I?m planning on keeping those.
Ive sent a few emails to Klaus in the past few weeks and havent gotten a response either. So its not you. With all the COVID BS happening, who knows his current situation, so i wouldnt take it personally :)
To the OP:
1. Even if that technology were true, I would not trust their manufacturing and Quality Control until they become much much larger (though they won't, because the technology sounds like BS). I can see it potentially working if they use some internal capacitance and circuits to store the charge and then release it in two time-spaced intervals. That gives me reliability concerns from a no-name manufacturer. It is a lot to put into a small package running in a high temperature and vibration environment.
2. You may be running too low of a power setting. I would try adding Decalin to your fuel:
https://www.aircraftspruce.com/search/search.php?s=decalin fuel additiveI
Does anybody use the Mazda rotary engine spark plugs
BR8ET
They have side electrodes like aviation plugs...
An unaltered engine will run within the optimum operating range straight from the manufacturer, but if you make modifications such as adding a turbo or supercharger, increasing compression, timing changes, use of alternate fuels, or sustained use of nitrous oxide, can alter the plug tip temperature, necessitating a colder plug.
A good rule of thumb is, one heat range colder for every 75–100hp added.
In identical spark plug types, the difference from one full heat range to the next is the ability to remove 70°C to 100°C from the combustion chamber.
A&P, IA
NC State, 1992
Retired Army 27y 5m 25d
First flight 8 May 1977
C-172, 177, 182
PA-31
7-AC
RV-6, RV-12, RV-8
In identical spark plug types, the difference from one full heat range to the next is the ability to remove 70?C to 100?C from the combustion chamber.
A&P, IA
NC State, 1992
C-172, 177, 182
PA-31
7-AC
RV-6, RV-12, RV-8
Plug heat range doesn't affect heat within the chamber, only the temperature of the firing tip of the plug.
