Old 03-09-2017, 08:55 AM
kaweeka kaweeka is offline
Default Sticking fuel valve
I tried this back in August without any responses so I thought I would resurrect it once more in hopes someone can help. I have an Andair FS 20 valve with left and right at 45 degrees, off facing aft. It is getting very difficult to switch between tanks. While everything was apart with the panel upgrade, I cleaned what I could without taking apart the valve itself. Has anyone has a similar problem with the Andair valve sticking? Are there user serviceable parts inside? So far, Andair hasn't been much help other than to suggest sending it to them.
David
RV-9A N435KR, Vans calendar March 2018
LIO 320 B1A, Dual LS Plasma III, AFP injection
G3x touch
Roseville, Ca
Old 06-30-2020, 11:38 AM
reak's Avatar
reak reak is offline
I have a similar sticky Andair fuel selector. Can these valves be serviced or lubricated without returning it to Andair?
Thank you,
Brad
Brad Reak
RV7A Flying, N789W
Loveland, CO
Old 06-30-2020, 12:13 PM
rocketbob's Avatar
rocketbob rocketbob is offline
Sometimes a drop or two of oil on the shaft takes care of a sticky fuel selector.
Please don't PM me! Email only!
Bob Japundza CFI A&PIA
N9187P PA-24-260B Comanche, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 06-30-2020, 01:20 PM
Ralph Inkster Ralph Inkster is offline
I just tried to find an exploded view of an Andair valve, no luck there. Only illustrations show how various fittings could bolt to the sides of the valve. I don't think lubricating the top shaft would work it's way down to the binding surfaces inside without actually disassembling the whole valve. If you do get the valve apart, I bet you will need a bunch of specialty seals to reassemble it...
Ralph
It's time to work on just my own planes, not everybody else's...
Old 06-30-2020, 03:11 PM
That one was resurrected from a few years ago. A few drops of lubricant seemed to do the trick. It usually lasts until my next annual so I've made that part of the list of things to do.
G3x touch
Roseville, Ca
Old 07-01-2020, 09:32 PM
reak's Avatar
I?d be happy to lube it at the condition inspection but with what lubricant? Do you let it drip down the selector shaft?
Brad Reak
RV7A Flying, N789W
Loveland, CO
