Old 01-28-2020, 08:03 AM
Low Pass's Avatar
Low Pass Low Pass is offline
Originally Posted by Dave12 View Post
Read any articles you can find written by Walt Atkinson, George Braly or John Deakins . These guys are the gurus of lop operations. They have done years of research on the subject. There are many good articles on AvWeb. I lean as soon as the engine is running, enriched a little for the run-up, full rich for takeoff. When I go to 25/25 for climb, I’ll start leaning. You have to have the means of closely monitoring each cylinder and a well balanced injection system to get full benefits from lop operations. When I level out at altitude, I’ll do the big pull back to 20-30 lop. The bottom line, watch those cht’s. They will tell the story. I’m running dual pmags and Precision Silverhawk Injection and this combination is very efficient for lop operations. It saves a lot of $.
Same equipment, same procedures, very closely balanced injectors, same results. Watch the temps and lean away.
Bryan
Houston
Old 01-28-2020, 08:04 AM
Cannon Cannon is offline
FWIW, the FF x 14.9 = HP rule of thumb only works when LOP, as that?s the only time you know that all (well, most) of the fuel is being turned into work. Once you?re in the ROP area, unburnt fuel is going out the exhaust and the rule no longer applies.
1976 C-185
1947 J3C-65
RV-8 project
Old 01-28-2020, 08:21 AM
Papa Papa is offline
Originally Posted by svyolo View Post
Mike Busch also has a bunch of very long youtube videos. Several involve LOP. His claim, that makes sense to me, is that when LOP you can calculate hp by just multiplying the FF by a fixed multiplier. The multiplier changes a little because of compression ratio, which makes sense to me.
For "normal" NA Lycoming (8.5-1) he uses 14.9 X FF (in lbs per hour) equals hp. If running lower or higher compression pistons it would change the same percentage as the C.R., at least theoretically.
There is a very simple formula that calculates HP for an engine, and it varies linearly with C.R.
I believe the rule of thumb uses gal/hr, not lbs/hr (unless my IO-360 is producing 500+ hp in cruise )
Old 06-29-2020, 11:21 AM
sglynn's Avatar
sglynn sglynn is offline
Default lean of peak
Thanks for this thread on running LOP. So is running 25F LOP a good spot?
My RV-7A has IO360-M1B with regular mags, no tuned nozzles. Just stock Lycoming from Van's catalog and I'm flying behind Dynon's HDX. I tried the big pull recently and was pleased to see Dynon HDX tells me when you move from ROP to LOP. Its pretty cool. Plus the engine doesn't stumble. I thought it would if I pulled mixture too far past peak. But engine seems fine. Fuel Flow decreases a lot - a good thing. Percent power drops.
So for en-route cruise is it okay to do "big pull" to LOP and then screw the mixture while watching EGTs to get them 25F LOP? And should this be the baseline setting for en-route cruise especially at altitude when endurance is important? Should I write it into the POH?
thanks
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
Old 06-29-2020, 11:52 AM
sailvi767 sailvi767 is offline
If you are going to do a rapid pull to LOP leave the HDX in the normal mode. Do the pull and then select lean mode on the HDX. Slowly richen the mixture until you reach peak on the HDX then lean back to 25 LOP. If you do the big pull in lean mode you won’t get a accurate peak value.
George
Old 06-29-2020, 01:32 PM
Dave12 Dave12 is offline
thanks
How is your fuel flow spread aka GAMI spread?
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Currently restoring a 1978 Citabria GCBC
Old 06-29-2020, 09:35 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
You can run LOP happily well above 75% power....no problem.
80% and above 60-80dF LOP
75% about 40dF LOP
70% about 25dF LOP
65% or less 10-15dF LOP
IMPORTANT NOTE: Do not use Lean Find functions as a normal operational tool. Great educational tool, but they all wind you up further LOP than you think.
Work out your richest cylinder and use it as your reference.
Next trap most people fall into. If you are 80% power when ROP, and you lean to an appropriate LOP power, that should be a 10% BMEP drop, like the big old radial days. That means you will end up at 72% power, which serendipitously is going to be around 25-30dF LOP.
If you are at 72% power and ROP, you will end up 65% power when LOP, and that will be around 10-15dF LOP.
The simple answer is read all John Deakins articles carefully, they are sticked somewhere here on VAF.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 06-30-2020, 10:41 AM
sglynn's Avatar
Default LOP with Dynon
David and others
Thanks for this data on running LOP with Dynon HDX. I'll go fly, try and post any significant tidbits. thanks
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
