Old 05-30-2019, 03:19 PM
dsm8 dsm8 is offline
Default Viking canopy fairing
Hello Fellow RV-12'ers
I attempted the canopy fairing according to AKI, and it failed miserably. I purchased the canopy fairing from Viking and after lots-o-trimming I have a pretty good fit, much better than my previous attempt.
Any suggestion on the adhesive to use to put on the foam and canopy to secure it. Any and all advice welcome
Donnie Mac
Don "Donnie Mac" MacMillan
RV-12 12808
Finish kit 80% done 80% to go
donald.macmillan@ynhh.org
Old 05-30-2019, 04:07 PM
AirHound AirHound is offline
Default Pics
Can you post pictures Donnie Mac?
Old 06-12-2019, 11:55 AM
Tacco Tacco is offline
Don,
I tried the Viking part to save time and, although I got it to fit pretty good, it looked horrible compared to the KAI approach on other RV-12's I checked out. I removed it and followed the KAI. There are a couple of good videos out there that review the Van's approach that were extremely helpful. I strongly suggest you review your efforts in attempting the KAI and reconsider. It's not that hard if do a little homework and nothing will look as good.
Steve Morrow
RV-12 N12SM
Builder 121036
White Salmon, WA
2020 Donation Paid
Old 06-19-2019, 03:09 PM
Default Canopy Fairing
Thank you all for input. I am going to give the KAI a second attempt.
RV-12 12808
Old 06-20-2019, 12:15 AM
Vakashi Vakashi is offline
My KAI fairing turned out really well I am happy to say, but did require a lot of patient sanding and refilling. It is a really worthwhile pastime. A few tips. Do not over bend the curved aluminium piece. Bend it just enough so that the touches the required spot without any gap. That will prevent the characteristic bulge that you see on so many RV-12 canopy fairings. Sight along the length of the fuselage and adjust the curved piece so that it does not bulge beyond the fuselage side and makes a nice curve. This is the foundation of a good fairing.
The other tip is to mark the outline of the next smaller sized piece of cloth on the preceding piece so that you keep them all aligned correctly. I didn't and I wish I had as they all sort of crept downwards until I barely had any glass to trim off the upper side of the arms of the fairing. Also, I used grey pigmented resin for all the layers and I should really have gone for clear in successive layers so that I could see what I was doing.
