Old 08-04-2011, 01:34 PM
DanH's Avatar
DanH DanH is offline
Default One-piece Grove Gear
Grove aluminum gear legs are a popular option with RV-8 builders. Compared to OEM steel legs, the standard aluminum legs save 17 lbs and the airfoiled legs save 11 lbs. Both types are drilled for an internal brake fluid passage.
http://groveaircraft.com/cat1415.html
One subject at OSH this year was the idea of adapting one-piece gear to the RV8. Many (or most) RV8 ground loop incidents result in damage to the gear tower structures and forward fuselage skins. It is an expensive and time-consuming repair. One piece gear would greatly lessen many of the peak fuselage structure loads. The penalty would be the additional weight of the connecting section, but total weight is still likely to be less than a stock steel gear.
Grove is quite willing to build one-piece airfoil gear for the -8. They would like 6-10 orders, as they do for batch production of the two-piece airfoil gear.
Like you, I'm aware of sensitivity in certain quarters regarding design modification, and a one piece gear would require some modification of the belly. I'm not aware of any published work in this area, and I've done no personal review. I do recall mention of one-piece gears on past -8's.
If I had realized the possibility of a one-piece gear a few years ago, my airplane would have it....so I volunteered to open the subject.
Comments?
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-04-2011, 01:52 PM
benbell4140 benbell4140 is offline
Dan, I would of definantly went one piece if I had known they were willing to build them. I had a one piece grove gear setup on my avid flyer and it was very nice. Not trying to jack the thread but does anyone know the reason 8's don't use engine mounted gear?
Ben Bell
RV8 (sold)
Awaiting Kitfox SS7 kit
Old 08-04-2011, 04:18 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
I also inquired about the 1-piece gear for the -8 at Grove's booth and he said that while it is not currently available as a regular production item, they are more than happy to custom-make you a one-piece main gear for an -8 either standard profile, or airfoil profile, and either with or without gun-drilled integral brake lines. All it takes is a special order and some extra moolah and they'll gladly make whatever you want
It would be beneficial if several builders were interested at the same time to get together so they could manufacture them in a batch instead of one at a time... might even offer a substantial discount.
I may be mistaken, but I think Doug Ripley may have built an RV-8 using a custom Grove 1-piece gear some years ago. It might have even been that very first RV-8 I ever got to ride in. I knew nada about RVs back then.
Neal Howard
Airplaneless once again...
Old 08-04-2011, 04:19 PM
SHIPCHIEF SHIPCHIEF is offline
I see on Grove's site that they offer one piece gear for Skybolts and Stardusters in the same gross weight (or a few pounds more).
Are any of these adaptable? They seem very afforable. When I get home, I'll measure my plane and think about it.
Perhaps an RV-8a would be a good starting point, and the gear towers wouldn't need to be so big?
Still, the center piece of the gear would be under your legs...
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 08-04-2011, 05:07 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Back when I was building my -8, the one-piece was a rumor on the horizon - if it had existed, I probably would have really studied it and would have picked it unless I saw some clear reason it was a problem. Seems like an elegant solution to me!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-04-2011, 05:42 PM
PCHunt PCHunt is offline
Just curious, has anyone asked Van's why the plane was designed the way it is? Surely some serious modification to the fuselage structure where the new gear would attach would be required?
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 08-05-2011, 12:33 AM
DeltaAlphaZulu DeltaAlphaZulu is offline
I'm probably quite a long way from that stage, but Grove gear is already one of my planned modifications to stock standard kit. Yes, I'd definitely be interested, particularly that there is currently a good $USD - $AUD exchange rate.
Darren Rickett
RV-8: Empennage kit - working on it, Wing kit received
Gosford, NSW, Australia
Build Site: http://www.darrenrickett.com/rv8/index.php
Old 08-05-2011, 06:39 AM
jseavolt's Avatar
jseavolt jseavolt is offline
I spoke with Grove at Oshkosh regarding the 1-piece gear and they are very willing to make a batch once he receives enough orders. My deposit has already been paid.
Jason "Bacon" Seavolt
RV8 N143MS "Fiona"
6.5 yr build
1st flight 4/23/17
Painted 11/17/17: Tribute to F16 Arctic Aggressor (Eielson AFB, AK)
-Over 200 hours VFR/IFR flown during 1st 15 months
-Bronze Lindy OSH18 (still in shock)
Old 08-05-2011, 07:30 AM
DanH's Avatar
No.
Quick look, no detailed analysis: It would require reviewing the contribution of the two F-802M intercostal ribs (DWG 61) and designing a substitute if simple deletion is inappropriate. The forward section of the F850-1 belly skin would be removed and re-tasked as a center cover plate, or ditch the two F-861PP outboard cover plates and fabricate a new one-piece cover. Either way, 802K and L get a few more nutplates.
Again, first glance: Nothing about the outboard leg clamps would change. I'd retain the U806 inboard wear plate and its AN4 attach hardware, drop the U804 clamp bracket, but retain the AN7 bolt, with a hardened washer under the head.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-05-2011, 07:46 AM
Toobuilder's Avatar
Aside from possible protection against ground loop damage, what is the benefit of the single piece? It's more weight, plus you are still stuck with the towers intruding into the cockpit.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
