Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 11-04-2019, 02:02 PM
Toobuilder's Avatar
Question Replace GNS430 with GNX375 - pinout help needed
Removing a 430 in favor of a 375 and trying to plan the pinouts before I dive in. First off, the current configuration has the 430 driving a legacy GRT Horizon (WS) and a Gi 106 CDI.
Pinouts are pretty straightforward with the exception of the 430's VOR/ILS ARINC outputs. I understand the 375 does not have a nav receiver, but the glideslope indications on the EFIS and the Gi 106 should respond to the LPV output, right?
If so, then the "other" ARINC outputs provide the LPV info to the EFIS and 106?
What is the difference between the "VOR/ILS" ARINC and any of the other ARINC outputs? Is it just a label or is their a functional difference?
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 11-04-2019, 04:16 PM
Pdtofly Pdtofly is online now
Default GNX 375 pinout
Mike,
Send me your email address to hr2plt@yahoo.com, and I will send you a copy the GNX 375 pinout.
Brian
Old 11-04-2019, 04:54 PM
Toobuilder's Avatar
Thanks Brian, but I do have the GNX installation manual. I also have the legacy GRT - 430 wiring diagram supplied by GRT. Between these two docs I've been able to do a nearly pin for pin conversion from the 430 to the 375. The main exception being what to do with the missing VOR/ILS ARINC input to the GRT... It's missing on the GNX375 since there's no nav receiver.
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
Old 11-04-2019, 05:53 PM
Either remove, or cut and cap with shrink wrap, the ?ILS ARINC? connections. Change the efis programing so it doesn?t expect anything on those inputs.
Old 11-05-2019, 05:17 AM
h&jeuropa h&jeuropa is offline
As Bob says, just leave the VOR/ILS inputs to your ARINC module disconnected. The vertical guidance for GPS is contained in the GPS ARINC sentence. See the 430W Install manual rev E, page 5-4 for more info.
Jim Butcher
Old 11-05-2019, 07:54 AM
Toobuilder's Avatar
Thanks everybody.
Just to satisfy my curiosity, is the VOR/ILS ARINC sentence different from all the other ARINC ports? I thought the ARINC stream was a common buss that the various clients simply picked relevant info from, ignoring the rest.
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
Old 11-05-2019, 10:44 AM
Originally Posted by Toobuilder View Post
Thanks everybody.
This is a good question, I would like to learn more too. My guess is that the label is too simple - something like ?CDI deviation? - so different types of CDI data must be kept physically separate, requiring separate ports.
