Old 08-12-2019, 09:17 AM
Chippyjo Chippyjo is offline
Default RV8 spar lenght
Hi all, first post in advance of an RV8 build. Can someone give me the lenght of the wing spar? Currently building a small workshop where I would like to store the wings when built.
Thanks in advance.
Chippy
Old 08-12-2019, 10:05 AM
N546RV's Avatar
N546RV N546RV is offline
I don't know the exact length offhand but it's pretty close to the 10' mark. I can measure when I get home tonight if no one chimes in before them.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
https://www.meetup.com/Houston-Area-RV-Enthusiasts/
Old 08-12-2019, 10:31 AM
fl-mike's Avatar
fl-mike fl-mike is offline
9' 7" overall finished length (includes end rib flanges). Does not include fiberglass wing tip.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS, L3 Lynx NGT-9000
N164WM
N184WM reserved (RV-8)....finishing kit in progress. Titan IOX-370
Old 08-12-2019, 12:08 PM
Freemasm Freemasm is offline
Default Help me, guys
I'm not building an 8 (long story but it involves RV4 wings) but I have a question, please. All of the Vans construction/drawings I've seen has a similar design philosophy; spars spliced together in a "box beam" type center section. So, my basic assumption would be the spar length is 1/2 the air frame span minus the wing tips (plus the ~ 1" of spar extension for construction). My assumption was you'd round to 23'/2 - ~8' (depending on wingtip), so just over 10.5 feet. Where's the missing length? What am I assuming wrong? Your knowledge is appreciated. My apologies to the OP for any thread hijack. Trying to get smarter here. Thanks
Old 08-12-2019, 12:38 PM
longranger's Avatar
longranger longranger is offline
Thumbs down
For RV-7,8,9,10, and 14, there is only a stub spar that bolts to a built up fuselage center section. Different from an RV-3,4,6. The stub spars on my -7 spars only go 5-1/4 inches inboard of the wing skin.
Stub spar:http://www.mykitlog.com/users/displa...=177353&row=16
Fuselage center section:http://www.mykitlog.com/users/displa...195585&row=155
Miles (VAF# 1238, Paid up as of 2018)
RV-7 TU 904KM (reserved)
Wings Fitted and Finish Kit on site
Construction Log
Picasa: Empennage Album, Wings Album, Fuselage Album
1955 Cessna 170B flying since 1982
'To get something you never had, you have to do something you never did.' -Unk.
Old 08-12-2019, 12:52 PM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
Default 12 feet
From wingtip to end of the control rod, just about 12' exactly.
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on final wiring and the engine
84CX Reserved
Old 08-12-2019, 01:08 PM
Default Thanks
Thank you, Sir. I've seen that stub spar type construction in Piper world. Not ready to say it's better than the spliced spare construction I incorrectly referenced but I trust Vans engineering. I'm sure it makes the construction easier. Thanks for sharing and getting me more knowledgeable.
Old 08-12-2019, 04:30 PM
Thanks guys, I will make the correct size to suit. Now all us UK builders need is a better exchange rate :-(
Chippy
