Old 10-29-2019, 08:12 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
Update:
I have continued to get kickbacks with the light priming suggestions.
Is it due to my light prop? Need to retard timing?
I'm not interested in testing the retard timing option.
Before I do any damage to my starter, I've decided to go back to my dual slick mags. I've had 13 years of no kickbacks & a reliable starting system.
Thanks you for your suggestions.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
Old 10-29-2019, 08:41 PM
Robin8er Robin8er is offline
I also have a light wood prop and had the same issue. My start procedure is:
1) ensure ignition, mixture and fuel is off
2) rotate the prop slowly and let the pressure bleed off from the compression stroke.
3) start the plane as normal.
Getting the compression out seems to help drastically with kick back. It always seems like the first rotation is where I had issues from not having enough momentum to swing the prop, resulting in kick back. I started doing this after I broke a starter from the same issue. Since I've started doing this I haven't had any kick back.
Be super careful when doing this, you don't want to accidently hand prop it!
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
Old 10-29-2019, 08:44 PM
Yes. My kickbacks were always on the first rotation too.
1190+ hours
2019 Donation Paid
Old 10-30-2019, 06:21 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
We get comments pretty frequently about kickbacks with a couple of popular EI brands. Assuming you have the EI set as per manufacturer's instructions, a good battery and starter to swing the prop smartly, the cause is simply not enough retard during cranking. This is really a software issue which in itself, shows a lack of testing before product release.
A marginal battery or starter can cause overly advanced ignition timing while cranking as the crank slows locally as it comes up on compression.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 439.3 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 10-30-2019, 07:25 AM
M McGraw's Avatar
M McGraw M McGraw is offline
Originally Posted by roadrunner20 View Post
Surefly suggested I look at the voltage at starter to insure > 10V
My starter voltage is 12.8/12.9 volts.
FWIW, I've checked & rechecked timing to above.
The most likely issue is a lack of proper retard during starting; however, 12.8/12.9 volts at the starter seems unusually good. Is that the voltage UNDER LOAD during the start?
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 500+
2020 Dues Paid
The Dues Paid note is a reminder for me
Old 10-30-2019, 07:48 AM
rv6ejguy's Avatar
10V under starter load is a good number so that is not the issue. The only way you can get kickbacks is if ignition happens too far BTDC.
Old 10-30-2019, 07:53 AM
No. This was not under load. Since I?ve never experienced a load issue, I didn?t pursue it further. Not a tired battery either as it was replaced 6 months old.
Thank you all for your input.
1190+ hours
2019 Donation Paid
Old 10-30-2019, 07:55 AM
Toobuilder's Avatar
Does the surefly have a method to alter the start retard timing during configuration setup? The SDS products are user configurable and mine is set to fire 3 degrees AFTER top dead center any time the starter is engaged. This means there is no way to get a kick back no matter the prime, start technique, weight of the prop, etc. I know some other ignition products have a start retard functions as well, but it's only engaged on the first revolution of the prop. If it doesn't catch the first time, you need to cycle the ignition off and on to reset the retard. Is the surefly like this?
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 10-30-2019, 07:57 AM
Toobuilder's Avatar
Battery condition does not ensure that the starter is seeing the proper voltage. Need to test this under load. Easy to do and could very well be your issue.
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
Old 10-30-2019, 08:00 AM
No option to retard timing.
1190+ hours
2019 Donation Paid
