Old 09-22-2019, 09:34 AM
Default Performance Figures for the RV-12
In looking at the performance figures, a distance range is listed for the RV-12 running 5000 Rpm, and also at 5500 rpms.
https://www.vansaircraft.com/rv-12is...raft-details-2
Is it possible or advisable to run the Rotax engine at 5500 rpm on a whole tank of fuel?
I was under the impression that the engine should not be run at full throttle for more than 5 minutes.
Depending on how you pitch your prop, for climb or cruise, is running the motor at 5500 rpms for more than 5 minutes advisable? Or is it pretty close to the "edge". What kind of manifold pressure should be expected, at 7500 ft under normal ATM conditions?
Old 09-22-2019, 09:40 AM
Azjulian Azjulian is offline
5500rpm is the max continuous rpm of the engine
5800rpm is the rpm they call ?take off rpm? and they indicate a limitation of 5 mins at that
Old 09-22-2019, 09:45 AM
Dave12 Dave12 is offline
The 912 can be run all day at 5500. Both of the ones I had seemed to enjoy it.
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Currently restoring a 1978 Citabria GCBC
Old 09-22-2019, 09:54 AM
Thank you. The friend I fly with, usually runs between 5100 and maybe 5300 rpm.... we usually see about 102 to 107 kt IAS and 115 kt TAS, both coming and going, average, if close to 20 to 25C OAT. Plane is at 175 hrs, motor broken in, and with wheel pants and nose gear fairing.
Mods, can we close this thread?
Old 09-22-2019, 10:08 AM
I run 5500 all the time. You can run above 5500 into the yellow for 5 minutes.
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 585
LSRM-A Certificate 2016 for RV-12 N633CM
Old 09-22-2019, 10:24 AM
What's indicated fuel burn gals/hr on your Skyview 1000, vs actual fuel burn, at that pace?
