Mikeandmaz
Hey Guys,
I’m trying to install the Fwd Elevator pushrod CS00001, on to the C00006 control column, but the gap between the fitting is too small for the bearing of the pushrod.
Did anyone else have this problem and if so how did you open up the gap? I’m at a loss to how I can get anything down there to increase the gap, or would filing down the width of the pushrod fitting Be an option?
Mike
Mike
