attaching the tailcone until the avionics were done
JwWright57
Hi all, for those folks that put off attaching the tailcone until the avionics were done what did you do about the forward rudder cable attach points?
Once all the wires start to be run it would be difficult to get those in there
I believe it would be extremely difficult to terminate the rudder cables to the pedal operators if the wire harness was installed. There’s little room to access them afterwards. I temporarily attached the tail cone to the fuselage with clecos to establish the correct lengths of the cable attach links. Just bite the bullet!
