Old 05-25-2019, 01:57 PM
LUKLA's Avatar
LUKLA LUKLA is offline
Default Trim Tab Indicator Out.
RV 12 with dynon HDX. Elevator trim tab indicator (green indicator in HDX) disappeared??
It was there and working fine so far. now all of a sudden its gone.
Any suggestion how to get it back !!!
Lukla
Glendale AZ
RV-12
N316AM
Flying since June 2018
Close to 100 Hrs
Old 05-25-2019, 05:14 PM
bobg56 bobg56 is offline
Check the wiring in tail cone, mine had a terminal strip and the indicator wire was loose
Old 05-28-2019, 05:35 PM
LUKLA's Avatar
Thanks, appreciate ur advice.
Lukla
Glendale AZ
RV-12
N316AM
Close to 100 Hrs
Old 05-29-2019, 07:01 AM
DaleB's Avatar
DaleB DaleB is offline
It seems to be a pretty common problem. Ours was indicating erratically for a while. I finally tracked it down to a slightly loose pin in the connector back under the tail fairing. Now it's rock solid.
Dale
Omaha, NE
Previous RV-7 project (sold)
