vixen file mill for tubing spacers
johnbright
Friend
Squaring aluminum tubing spacers with a vixen file and drill press.
Somewhat tedious but controllable because the file loads up every 0.002".
215 RPM, the slowest speed of my drill press.
drill and scotchbrite wheel
I did something similar by spinning the tube in a hand drill and turning on the scotchbrite wheel - probably not quite as square as your idea, but pretty square.
I’ve done something similar, too. First I use a tube cutter, then I finish up by putting the tube in the drill press with a sanding block in place of the vixen file.
If you have a cross vice for the drill press, you can clamp up a lathe tool and use it like in a lathe to cut the end of the tube to the correct dimension.
I’ve also chucked a bushing in the drill press and dressed the end on some sandpaper. Easy to square it up, take off a thousandth or two, etc.
This approach works well and how I did it before the lathe.
+1, or alternately using a disk sander. Fast and easy way to get them the right length as well.
