pmercier
After being away from the project for 5 months I'm finally back at it. Here are the latest updates.
I Installed the Battery on the firewall.
For inflight entertainment I installed my XM Radio that will be wired to the intercom.
The Airbox is almost completed except for the alternate air and carb-heat access.
The wiring is pretty well wrapped up.
I put an air vent on the fuselage side for the rear passenger position.
The gascolator is bolted to the firewall with spacers to help clear the lower mount tube.
I installed the prop and torqued and safety wired it.
The pItot lines are run along the wing to the Dynon pitot/AOA probe.
I needed a charger connection that I will leave in the oil access door.
The throttle cable are now mounted to the bracket I fabricated.
A cowl fix to repair an gap I created when I overcut the side.
A canopy strut was installed to provide a cleaner installation.
I wanted the cowl pins to insert from the rear.
I put a bend at the rear of the pin to help lock it in place.
