Old 06-26-2019, 01:55 PM
GeoffP's Avatar
GeoffP GeoffP is offline
Default Aussie suppliers
Trent, I sent you a PM with info on a local supplier that I've used for electrical (and other) parts for my -9 build. It might help, it might not.
RV-9, Tail Feathers done, Wings almost done.
Old 06-26-2019, 05:04 PM
Joeyo68 Joeyo68 is offline
Hi Geoff,
Can you please send me a PM with the details also. I am wiring and have to buy more terminals.
Joe
Joe
Flying friends RV7A
Built RV7 empennage.
Building wings done - minus glass and lights.
Building Fuselage
Old 06-26-2019, 05:55 PM
Hi Trent,
RE: your original post; I suspect that you are overthinking it a bit. Note that, for instance, the TE-AMP 36154 you linked is spec'd as having a wire gauge of 22-18 in milspec, and 22-16 in commercial use. Consider that even with the milpsec size range, there is a *huge* variation in insulation diameter across those three sizes, even if you restrict your wire selection to one insulation type (there are numerous milspec insulations; you can likely still find a milspec for PVC). The military seems ok with a 3-gauge-range, both in wire gauge and insulation diameter. All you really need from the insulation 'grabber' in the connector is that it stabilize the wire outside the electrical crimp area, without cutting completely through the insulation. The insulation crimp exists to prevent the wire from flexing at the electrical crimp point, which is a stress riser, just like a solder joint.
It pays to remember that what we're doing isn't rocket surgery. :-) If that wide range of sizes in on connector is good enough for milspec, it's plenty good enough for me.
Charlie
Old 06-26-2019, 07:07 PM
TASEsq TASEsq is offline
Originally Posted by rv7charlie View Post
Hi Trent,
I am sure you are right.
Thanks Geoff. You are right - i am better to buy local than overseas, much quicker i think (even though digikey is pretty quick). I think i will just go for the listed part numbers in the AAE catalogue.
___________
Trent Stewart
Melbourne, Australia
http://www.tasrv14.blogspot.com.au/
Aug 2021
Old 08-06-2019, 03:44 AM
chaskuss chaskuss is offline
Default Wayne Wire
Trent, I get all my PIDG terminals from Waytek Wire here in the USA. I generally buy the terminals in packs of 100. Generally pay $0.20 a piece or less for them. Not sure what their shipping policy to Australia is? Their shipping to points in the USA is very reasonable.
Old 08-06-2019, 10:54 AM
Trent,
Check your private messages here on VAF
Charlie
Old 10-24-2019, 08:14 AM
rocketbob's Avatar
rocketbob rocketbob is offline
Recently ordered double crimp connectors from ferrulesdirect.com. These are the same PIDG knockoff double-crimp terminals mentioned previously in this thread. Prices and quality are excellent.
http://www.ferrulesdirect.com/electr...NYD_MDFNYD.htm
250 sizes are what are normally used in the electrical system.
Please don't PM me! Email only!
Bob Japundza CFI A&PIA
N9187P PA-24-260B Comanche, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
