Hi all,
I have a question I did not find anywhere.
At the moment I installed the rudder pedals (Control Approach) and I'm going to create the short steel linkage
with the rudder cable.
I see that the pedals seems to stay not in vertical position but a little bit back.
If I connect the cable, the length of the linkage can change a lot depending by the absolute position of the pair of pedals.
I mean, If I'm driving the pedals during flight usage, my feet are placed on them and so they pull the cable and the situation is ok.
But if the pedals stay in rest, the cables do not stretch and the pedals move on the same direction together (back).
I'm thinking to put a short mechanism to fix the possibility that both pedals together can move back.
What do you think about ?
thanks a lot
Francesco
thanks a lot
Francesco
