mc607
Yes, I did it. While working on my fuel tank I dropped the 1.7 lb tungsten bar. I had foam in place against the rib flange but the bar landed in a very small unprotected area adjacent the tabs at the nose section of the rib. It produced a .018? dent outward and a small crater type ding on the inside right on the most fwd part of LE of tank. I was able to massage dent back in and sand/feather out ding on the inside. The end result is an area about 1-1/2? dia skin reduced to approx .020? (original is .032?). The plan is to proseal on a doubler over damage. My question is this ?has anyone done a similar repair, anywhere on the plane, and had issues with it down the road??
Side note: I made up a small piece of the tank section out of .032? material and dropped the bucking bar into it 6 times from the same 21? height. I wanted to try and replicate the damage and try my repair method on it before going at the tank skin. In the process, out of the 6 drops 3 of them punctured the skin badly. I only mention this to make sure everyone is using suitable protection when completing this step. The foam I was using, in hind sight, was not enough.
