Anyone putting the new nose gear on a -6A?
Brdog42
Yes, no?
I?m rebuilding an -6A which had an engine failure while in the pattern 15+ years ago. 250 TTAF. Jim, the owner/pilot, my IA & former co-worker, was able to land on the runway. The only damage was a seized IO-360 angle valve the original builder installed. Jim was the second owner. The airframe sat in the back corner of Jim?s hangar until last August. He also had a new IO-360 parallel valve in a crate and a new engine mount/nose gear. The original engine needed a different mount.
So, now I?ve this -6A in my hangar with that crate IO-360 & engine mount. Jim passed it on to me. :) I?ve hung the engine and added baffling. But nothing else... no fuel lines, throttle/mixture cable, etc. It?d be the time to add the new nose gear.
I?ve basically a super quick build kit with an Airworthiness Certificate. A clean slate. The interior is completely removed. No instrument panel. I?m still not sure where I?m going with it. Mostly day VFR sightseeing trips for friends around AZ. I fly IFR at work and don?t feel the need to fly IFR in the -6A. Not with the IMC conditions we get in AZ, anyway. The -6A will be better with our DA?s than the A150L. Although I miss that Cessna.
Tim
Van's brought a fuselage with the new nose gear setup to Oshkosh. It's almost identical to the one on my RV-14A. I'm not 100% sure but it looks like you have to get a new engine mount also.
6A. Nose gear
Replace it! Never thought mine would give way, did all inspections, babied it on touch down, and seldom landed on grass strips. Still failed with 1500+ hrs on it.
New gear gets matched to old one and no engine mount replacement unless it was busted on prop strike incident.
Excellent investment!
