Drill Guide?
spriteah
Hi all, I have come to a spot on page 08-03 where it refers to a drill guide to assist with drilling the hinges. Part No. HS-1223.
Should this have come with the kit? Cannot find it. Any help appreciated.
Jim.
The drill guide was included in the kit;
If I remember correctly, the drill guide came in one of the very early kits - empennage I think. Check the inventory sheets.
John
It was in one of the bags of the empennage kit. Actually they provided two as the holes will wear out a little over the use ...
When you find it, be careful to realize that each side is different. Very easy to get it flipped over when moving it down, then you get to buy a new hinge.
Yeah I got a little drill happy and drilled all for pieces one way, OOPS, hello Aircraft Spruce, I need a hinge :)
Found it. Thanks.
It worked out good. Today I found it hidden away. Taken all your advice and started drilling. Thanks all for the help.
Jim.
12130.
