Old 12-07-2019, 02:17 AM
Stewbronco Stewbronco is offline
Default Inverted brake fluid reservoir
Any recommendations on inverted brake fluid reservoir on RV4 ? Thanks. Stew pictures are worth a thousand words 👍
Old 12-07-2019, 07:12 AM
vlittle's Avatar
vlittle vlittle is offline
Replace the plug with a fitting and run a vent line to below the reservoir, exiting the cowling. You could also install a check valve at the top of the reservoir instead or in addition to the vent line.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 12-07-2019, 09:06 AM
JonJay's Avatar
JonJay JonJay is offline
http://reservoirdog.alexap.com/index.html
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 12-07-2019, 01:43 PM
Norman CYYJ Norman CYYJ is offline
I have had success using a PVC valve. Cut the flared end off and then thread to match the reservoir. It acts a check valve.
Old 12-07-2019, 01:49 PM
penguin penguin is offline
Use a solid plastic plug in the reservoir, I've never found a vent that didn't leak during acro, esp rolling circles! Be aware that the brakes will feel soft at some point, take the plug out and let some air in. Brakes will feel fine again. Needs to be done 2 or 3 times before the pads are worn out.
Pete
Old 12-07-2019, 03:56 PM
mdevans9 mdevans9 is offline
Default Reservoir Dog
+1
Works great. Never a drop, but I don't do rolling circles in my RV-7. Just the usual Sportsman stuff.
Merrill
Merrill D. Evans
N87EM
Old 12-07-2019, 10:35 PM
Default Reservoir dog
Originally Posted by JonJay View Post
Perfect ... this was what I was looking for just couldn't remember the name. Many thanks. Stew
Old 12-08-2019, 04:41 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Fill the reservoir 2/3 full and plug the vent hole. There is enough air in the top of the reservoir to allow fluid to flow as required.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2020 Donor
Old 12-09-2019, 08:17 PM
SJordan SJordan is offline
I use these on my smoke tank and my brake reservoir, spend lots of time inverted and not a single drop of oil has ever come out! Work amazing.
Shawn Jordan
KDVT
RV4. N11XZ
2018 dues paid.
Old 12-10-2019, 04:35 AM
WingsOnWheels WingsOnWheels is offline
I used a reservoir for a hot-rod. It has an automotive-style diaphragm seal under the cap. I did mine this way since I am using DOT4, but it would serve the purpose for inverted flight as well. Looks nice too.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
I donate every year on my B-Day (in Dec), but donated early in Sep'19.
