Old 06-19-2019, 03:00 PM
Flandy10 Flandy10 is offline
Default TDI 200 hr report
Departing IndyJet at KMQJ for home after Memorial Day weekend.
Ok, it is not a stunning newly painted plane photo, but it's my favorite so far.
And considering it looked like this...
for most of Feb. thru early May during this year's condition inspection, it sure felt good to be back in the air. It still hurts to look at this photo.
What happened? It was time to fix the following items.
1. improve oil cooler air flow
2. modify fuel cooler installation
3. fix left fuel tank wingwalk rivets that started weeping--- AGAIN.
4. improve lower right dynacup alignment
5. resized cowling inlets
6. improve fuel pressure at altitude with new high output pump
Results--
Oil temps are about 10F cooler in climb and cruise, but the CHTs also dropped about the same- didn't see that coming. The CHTs are already cooler than I want.
No weeping tank rivets and I was able to hang the engine- solo- in 15 minutes, so the alignment issue was greatly improved.
Also got in a trip to the factory's Experimental hangar in Mobile for a checkup.
They have the only compression check and borescope equipment for this engine right now. Clean bill of health!
Scott Flandermeyer
Rv-10 TDI 275 hrs
Fayettevile, GA
2020 VAF Donation complete
Old 06-19-2019, 03:36 PM
rdrcrmatt rdrcrmatt is offline
I am so jealous of that engine.
Matt
CFI / RV-10
Old 06-19-2019, 05:06 PM
AviatorJ AviatorJ is offline
That hangar looks as cool as the plane... almost.
Justin
RV-10, N10JW
First Flight 2/14/2019
http://operationrv10.blogspot.com/
Old 06-19-2019, 05:13 PM
dreed dreed is offline
Silly question, but what engine is that? As a diesel lover I am intrigued.
Dan Reed
Camas, WA
RV-7A - Slider in progress - N167DR (reserved)
Working on finish kit/cowl
2018 and 2019 VAF dues paid
Old 06-19-2019, 06:12 PM
Prototype of CD230. Production engine will be CD265.
Scott Flandermeyer
Rv-10 TDI 275 hrs
Fayettevile, GA
Old 06-19-2019, 06:34 PM
catmandu's Avatar
catmandu catmandu is offline
Yellow fan at a diesel shop. Luv it!
Mike C.
Sierra Nevada
RV-6A bought flying
Old 06-19-2019, 10:28 PM
jeffwhip jeffwhip is offline
Thanks for the update! Did Continental happen to say when you'd be getting the production engine? When will it be available to the public? The plane is looking great.
Rudder - Complete
Horizontal Stabilizer - Complete
Vertical Stabilizer - Complete
Elevators - Complete
Cabin Cover - Complete (wheewww!)
FWF - Complete
EFII 32 - In Progress
Dues Paid Through 2020
Old 06-21-2019, 05:26 PM
rongawer rongawer is offline
Glad to see the engine running well. I'm very much looking forward to hearing if/when it becomes available. I know I'd pony up for it.
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"...many great hours and happy landings so far.
- Several others that are now just great memories for me.
Old 06-21-2019, 07:55 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Thanks for the update Scott.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 439.3 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 06-23-2019, 07:06 PM
Default Fuel Bill
I believe the following to be accurate.
1/2018 to 1/2019
86.5 Hobbs hours
575 gallons purchased at $1946.27 avg $3.385/gallon
6.65 gph
Scott Flandermeyer
Rv-10 TDI 275 hrs
Fayettevile, GA
