Old 10-03-2019, 03:07 PM
abeus abeus is offline
Default A New Sunshade
I am working to develop a new shade for vans aircraft and am wondering how much people would be willing to pay for a sleek, elegant canopy shade?
Old 10-03-2019, 03:29 PM
mulde35d's Avatar
mulde35d mulde35d is offline
Default Typical answer, depends
Really depends how slim, how well it works, and how rugged is the design. If you came up with a thin design that could be repaired, replaced, or just never wore out while effectively blocking the sun I would gladly pay a few hundred depending on the quality. I bet you would cap out quickly though at anything over $500 since Kroger is a descent product and under $250.
For me personally the thickness is the most critical aspect since my head is within 1” of the canopy with a headset on. Just my opinion, use at your own risk. Second greatest concern is the invasiveness of the install. In particular, afixing something to the expensive canopy that is difficult to replace would be least desirable. Would also need to be retractable / removable for things like aerobatics if the large RV population were your target audience.
Happy to beta test for you as I am about to order the finish kit on a 14A If you desire.
Jon
http://www.mykitlog.com/mulde35d
RV-14A Sold
RV-10 Research In Progress
Old 10-03-2019, 04:43 PM
catmandu's Avatar
catmandu catmandu is offline
I am a suction cup sun shade user. $10 each at big box stores, and you can position them exactly where you want them. I occasionally get whacked in the head when a suction cup breaks loose. I kind of like that wake up call, so I put it back in the same place, over and over, and get whacked again.
I do this because I can't stand to sacrifice visibility for shade, like one must with the rail system of certain shades. You find a way to mount a quality shade over the top half of a tip up, that is removable when not needed, but still stays in place, and does not rub against my headset, I'd give you $200.
Mike C.
Sierra Nevada
RV-6A bought flying
Old 10-05-2019, 07:16 AM
Thanks for the input! This is great! I would definitely be interested in have you (catmandu) beta test it once I get things a little more ironed out. The more feedback the better.
Old 05-07-2020, 08:06 AM
Gyrodoug Gyrodoug is offline
Any pictures of your shade setup???
Thanks.
Old 05-07-2020, 08:35 AM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
I'm very interested but haven't bought anything for the same previously mentioned reasons. Can't find myself attaching anything that could scratch the canopy and I don't want something permanent to get in the way of my view when I don't need it, like when doing acro.
If you can come up with something that will not scratch and won't fall off, I can test it on my RV-8 in the Texas heat to see if it withstands the acro and doesn't fall apart.
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
Old 05-07-2020, 04:20 PM
plehrke's Avatar
plehrke plehrke is offline
I have same setup and familiar with the falling shade but still i believe is my best option. I like the flexibility of moving it where I need it with minimal vision blockage.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 05-07-2020, 05:12 PM
emsvitil's Avatar
emsvitil emsvitil is offline
I recall reading (on the internet, so it must be true) about a tint that you could control.
It was either clear or opaque (with in between stages)
or
variable darkness
Ed
Old 05-16-2020, 11:38 AM
Paul 5r4 Paul 5r4 is offline
Smile
Another suction cup guy here. I did have some roll out auto shades that were mounted on the forward part of the roll bar area. Problem was... and it was frequent... that the sun would be well below the shades. Took them out and now have two of the fold up type. I've discovered they work extremely well. Here's why. First they are completely mobile to anyplace on the canopy even right down to the lower canopy rail. I've also discovered that when the sun is bad enough, I can overlap them and it really helps in controlling the suns radiant heat that makes it through only one to strike me. They are stored between the seats, deployable in a couple seconds, easily moveable, and just as quickly stowed. Like previous post mentioned.... around 10 bucks. I like simple!
P.S. Also as mentioned earlier, the occasional hit in the head wake up call is good too! :-)
Paul Gray
Foley, Alabama
N729PG..... 450+ hrs
RV 7A, Lycoming 0 320 D1A, Sensenich FP propeller
pilotforfun2001@yahoo.com
VAF supporter $$$
Old 05-16-2020, 11:47 AM
bjdecker's Avatar
bjdecker bjdecker is offline
or
variable darkness
https://www.smarttint.com/
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
