https://ronslosberg.com/ Ron's RV-14A Build Log
reusing paint solvent
The priming you've done looks good. If you will put your dirty lacquer thinner into a container the paint will usually settle out. Then you can pour off and reuse the clear stuff. I use mason jars because they seal well and you can see when the solvent becomes clear. I've never used the paint you are using but it works on everything I've used. Good luck with your project.
Blog looks great. I remember when my shop looked as neat as yours. Not so much these days, but I'm a LOT closer to flying.
Enjoy the build!
