I was hoping someone might be able to help me with a problem I'm having with my timing display on my new RV-6 panel. It seems to read backwards. i.e. 28 deg at TO and 25 deg at cruise. I have the timing interfaced to my G3X touch display with the L2e unit. Since there is only one signal wire (pin#3 of the output connector, Plasma 3), it seems to me there's no way of getting the signal reversed. The only other possibility I could think of was reversed calibration settings on the display unit but that checked out good. It also reads accurately at 0 RPM (0 deg). The static voltage and ground on the unit checks out at +5v. Has anyone ever seen this problem? The timing display was working fine with the old LCD module so I would say that eliminates the output connector.
The folks at Flight Data Systems are as puzzled as me. I'd really be interested in any thoughts on this.
John (Jacksel) Walsh
83FL, Yulee FL
83FL, Yulee FL
