Old 01-19-2020, 12:35 PM
SMRacer SMRacer is offline
Default Dynon COM display
I recently installed a Dynon COM 25 replacing my Garmin SL30 in my RV8. The radio is positioned in the same spot as the Garmin, just below the AFS 5600 EFIS. The Dynon display washes out considerably if you are not looking directly at the display. Obviously I am looking down at about a 30 degree angle and the display becomes very difficult to see. The freq also displays on the AFS EFIS so this is not a major problem, but I'm curious to know if anyone else has experienced this problem, and any recommended solutions.
Jim
Leesburg, VA (KJYO)
RV4 N444JT (sold)
RV8 N37PK
Old 01-19-2020, 01:17 PM
Carl Froehlich's Avatar
Did you adjust the display brightness?
Old 01-19-2020, 01:35 PM
Are you talking about the AFS display brightness? I have found no way to change the brightness of the Dynon only. Only information I've found on the Dynon Com is in the Skyview HDX manual on the Dynon site.
Jim
Leesburg, VA (KJYO)
RV4 N444JT (sold)
RV8 N37PK
Old 01-19-2020, 03:11 PM
Jim,
Sounds like you need to give Rob Hickman at AFS a call.
Old 01-19-2020, 04:04 PM
sailvi767 sailvi767 is online now
I don?t believe there is a way to adjust the Dynon radio display brightness. If there is I would love to hear it.
George
Old 01-19-2020, 05:48 PM
George
From high noon to after dark, there is a huge difference in ambient light. Look for a photocell, make sure it isn?t somehow blocked.
Old 01-21-2020, 08:12 PM
N546RV's Avatar
N546RV N546RV is online now
From my recollection and a quick scan through the Skyview install manual, in a Skyview system the display(s) act as the dimming controller (they have a photocell) for the entire system, and dimming is coordinated either over the Skyview network or through a display's external dimming output (for non-SVN devices).
Ergo, in a Skyview system, I'd expect the radio to adjust its brightness in coordination with the displays. However, I'm not sure how this translates to a system with AFS screens. My detailed knowledge is sort of necessarily limited to my system planning.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
https://www.meetup.com/Houston-Area-RV-Enthusiasts/
Old 01-21-2020, 09:02 PM
I rarely fly at night so the AFS display is generally on full bright. I will check to insure that is the case the next time I am at the airport. The Dynon is perfectly readable now if I aim the display directly at my eyeballs. The more it is angled away the more washed out the display becomes. I am contemplating building a shim to angle the radio up 10-20 degrees.
What I really want to know is if others using this radio are experiencing the same resolution degradation.
Jim
Leesburg, VA (KJYO)
RV4 N444JT (sold)
RV8 N37PK
Old 01-22-2020, 04:20 AM
Jpm757 Jpm757 is offline
When I manually step dim my AFS5600t displays, at one point the Com display begins to dim.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 300+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
