Old 12-21-2019, 08:31 AM
Patr Patr is offline
Default Would Like to Order a Complete Kit for 0320
Hello, I would like to order a complete set for my 0-320. I have 1 3/4 inch diameter induction tubes. Red would be good or whatever color is available. Please PM me with the details on completing the order.
Thanks Pat
Pat Ryan
RV6A
Ramona CA
Old 12-21-2019, 03:42 PM
Mark33's Avatar
Mark33 Mark33 is offline
Thanks Pat
Pat,
You?ll have to go to Ross?s website to order the parts or give him a call.
http://sdsefi.com/cpi2.htm
Mark H.
RV-7- IO-360, EFII, Whirl Wind C/S, (Built and sold)
RV-4- O-320, Catto three blade, P-Mags (Sold)
RV-8- IO-360, Hartzell C/S (Flying)
RV-7- (Building)
Old 12-21-2019, 05:51 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
I sent a PM to Pat early this morning.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 439.3 hrs. on the Hobbs,
RV10 95% built- Sold 2016
Old 12-22-2019, 12:13 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Superior sump idea
I have the superior sump as shown in the photo.
@Ross - would you guys be able to pre-buy some of the tubes, and then offer a kit which is already welded? Then we could send you back our tubes to be re-welded for the next guy. Like returning an empty coke bottle.
I'm sure that there is a market for that - charge a lot.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 12-22-2019, 08:59 AM
rv6ejguy's Avatar
Unfortunately my ace welder friend retired last year so I don't have an economical alternative who can do top quality work.
Ideally, if Superior would be agreeable, they could install our flanges during the manufacturing process if they'd agree to respect my IP.
Old 06-06-2020, 09:38 AM
rv6ejguy's Avatar
We just received another run of flanges from the machine shop and anodizer on Friday so have a decent stock of clear, gold and red flanges in stock again for those interested. As always, thanks for your patience.
Our machining partner who makes these is working 7 days a week to try to keep up with demand for his services from SDS and other clients. He'll be adding a new Haas VF-4 in the coming months and expanding his shop space to the adjacent bay to accommodate it. This should reduce lead times on many of our parts- but I've said that before...
Old 06-06-2020, 09:53 AM
HAL Pilot's Avatar
HAL Pilot HAL Pilot is offline
Aloha
I'm a bit confused with the welding discussion. I have been led to believe that it is really hard to weld anodized aluminum without having to remove the anodizing layer and thus making a mess.
Are these flanges welded on?
Pete
RV14A Tail kit build mostly done
Wing kit in progress
RV 14 WIKI in process, residing on Drop Box
https://www.dropbox.com/sh/xu5p6f4l7...bU0ck0pJa?dl=0
change dot org link http://chng.it/KBPtXZYD
---For Edit Access drop me a PM with your Email address.
EAA 1300
Donation Paid 2018,19,20 Military exempt but paid any way Cause its worth it.
Old 06-06-2020, 10:00 AM
9GT's Avatar
9GT 9GT is offline
A high quality product that does the job. I put a set on my not flying yet IO-320 RV-9A. My build buddy put a set on his IO-360 Cozy MKIV. He states there was a noticeable improvement in how his engine ran afterwards. Thanks for making this kit available, and at a very reasonable price IMHO.
David C.
Howell, MI
RV-10: #41686 Under Construction
RV-9A: #90949 Under Construction
RV-10: #40637 Completed/Sold 2016
Cozy MKIV:#656 Completed/Sold 2007
"Donor Exempt" but donated through Dec. 2020
Old 06-06-2020, 10:01 AM
Toobuilder's Avatar
The welding only comes into play if the flange blocks cant slide on/off the tube as typically seen on the angle valve engines and some aftermarket examples. In these cases, the tube needs to be cut to remove the old flange blocks and install the SDS parts, then the tube is welded back together.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 07-08-2020, 04:07 AM
longez360 longez360 is offline
I installed mine today on a Lycoming O-360 A2A.
Very impressed with the idea, and part quality.
It was a very straightforward and easy installation.
I used Knipex Cobra 250mm Spring Hose Clamp Pliers 85 51 250 A. These are superb.
Can’t wait to run the engine.
Cheers
Wayne Blackler
IO-360 Long EZ VH-WEZ
AUSTRALIA
