Old 01-25-2013, 09:18 PM
nzrv8's Avatar
nzrv8 nzrv8 is offline
Default RV-8 fastback advice please!
I know this has been discussed in previous posts, but I'm chasing the most current opinions so I can make my decision.
Questions:
1 - Does anyone make a fastback slider kit anymore?
2 - Regarding the Showplanes tip-over kit - Would those of you that have done this conversion consider it a straightfoward task? I have a QB fuselage and I understand there is a bit of disassembly involved - New cockpit rails etc.
3 - Fastback conversion time vs standard Vans canopy build time?
Thanks!
Hugh
Old 01-25-2013, 10:05 PM
flyboykelly's Avatar
flyboykelly flyboykelly is offline
1. I don't think so.
2. The showplanes kit is great! Shouldn't be to bad to convert.
3. It's definately more time, but I think it's worth the extra time.
I have a showplanes fastback that I converted to a slider. I used the standard vans slider components except I needed to fabricate a new insert for the turtle deck. The canopy was a different story. I used the forward steel bow off of a vans canopy frame and made the rest of the frame out of composites. I have some pics of the canopy and turtle deck at:
http://www.facebook.com/radialconversions
I hope this helps,
Brian
Flying as of 1-12-2016!!!!!
Old 01-28-2013, 04:38 PM
nzrv8's Avatar
Thanks Brian!
Old 01-29-2013, 08:36 AM
RDSIII RDSIII is offline
Hugh, I am working on the standard Show Planes tip over now. The kit is very complete and straight forward. I can only really answer your second question though. There has been some dissassembly but it was very simple. The cockpit rail dissassembly took about an hour to complete. I drilled off the rivet heads only, then popped the rails off and lightly punched the rivet shafts out of the holes. Use an undersized bit for the rivet head removal and be sure you in the center of the rivet. I prepunched all the rivet heads with an auto center punch to get a good divot. he helped me prevent wormholing the bit. I also have a small Souix palm dirll that has very precise speed control, which also helped.
The hardest part for me was step one - cutting up your newly built vertical stabilizer! Once you make that cut, the rest is easy.
Robert
Robert D. Saul III
RV-8 QB
Old 02-05-2013, 11:35 PM
BHunt BHunt is offline
What about this guy?
http://www.toddscanopies.com/index.php?id=130
Scooby
Harrumph!!
RV-8 IO-390 N788MT
Old 02-05-2013, 11:44 PM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
Originally Posted by BHunt View Post
I'm pretty sure Todd's only offers the acrylic transparency; I don't think he sells anything in the way of frames or skirts for either slider or tipover.
Thanks, Bob K.
Bob Kuykendall
HP-24 kit sailplane
EAA Technical Counselor
Old 09-26-2018, 12:52 PM
MikeThePilot MikeThePilot is offline
I haven't been able to find anything answering this in the forums or on the Showplanes site...
How is the rear cargo area accessed with their fastback mod?
It looks like the rear seat back should tip forward or be removable; if that's the case, can anyone comment on what it's like to live with? Is it hard to access?
Mike
Old 09-26-2018, 03:14 PM
DanH's Avatar
DanH DanH is online now
Exactly like a standard RV-8.
While the "door size" is the same, the increased compartment height is really handy.
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-27-2018, 10:32 PM
jefferts jefferts is offline
Default Todd's Canopies
Sadly it is my understanding (via the Todd's Canopies Facebook page) that Todd of Todd's canopies passed away recently as a result of a plane crash.
Old 10-14-2018, 10:00 AM
Taltruda Taltruda is offline
Default Fastback options
I really like the fastback look, but I think the showplanes setups that I saw don?t quite do it for me. I would want a straight line from canopy back to the aluminum. The showplanes that I?ve seen still have the bubble look. The only version that looks right to me is the Rocket setup. Who else makes a fastback version? Or can the showplanes setup be cut down to achieve the straight line that I?m looking for?
Tom
Las Vegas
RV-8 empenage almost finished
Horizontal Stab done! 2-15-2020
Vertical Stab Done! 5-27-2020
Rudder Done! 5-31-2020
Wings ordered!...
