Old 05-14-2018, 08:04 PM
Maverick972 Maverick972 is online now
Default Slider newbie question
I have an RV7 slider, I love it and it?s the best option for me.
Sometimes I don?t want the slider to slide all the way back but would like it open a few inches.
How have others made this happen? Thanks
Sean P. McGrath
RV7 730JK
2020 Dues Paid.
Old 05-15-2018, 07:49 AM
rvsxer rvsxer is offline
For when my RV-6 is parked I have a second slot for the lock that leaves the canopy open 3-4". Maybe you could drill a hole in the track and have a spring-loaded pin that you push down into the hole. It should stay put while the canopy is open due to the canopy wanting to slide open further (at least on a taildragger). To disengage it, push the canopy towards closed a bit, the pin pops out and you can open or close the canopy all the way. Having the "default" pin position as disengaged lessens it interfering with a hasty exit.
Mike Hilger
RV-6 N207AM w/G3X, 1,600 hours +
South St. Paul, MN (KSGS)
A&P, EAA Tech Counselor
We're all here because we're not all there...
Old 05-15-2018, 04:18 PM
Bicyclops Bicyclops is offline
It ain't elegant, but I use a spring clamp on the slider side track about 10" aft of the front. The roller butts up to it preventing the slider from moving any further and requiring me to duck my head as it passes. When not in use, I clamp it under the armrest.
Ed Holyoke
Old 05-15-2018, 08:14 PM
Champ's Avatar
Champ Champ is offline
Used a couple of Mike Zeller canopy latches on my 8. One at a couple inches open and one at half open. Don?t know if these would also work on a 7 slider.
Dennis Enns
Kingsville, ON
Bellanca Champ 7ACA since 1986, restored 1990.
RV-8 IO375, Hartzell CS, dual PMags.
2020 Donation In
Old 05-15-2018, 09:08 PM
JonJay's Avatar
JonJay JonJay is offline
Ed Holyoke
Perfect!
Light weight, portable, stow-able, could be used for a variety of purposes. Handy weapon in a nipple pinching contest.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
