Old 04-13-2019, 01:01 PM
Walt's Avatar
Walt Walt is offline
The below chart is generally considered the "standard" values for balancing.
My goal is 0.050 IPS or better when balancing, .010 is very seldom obtainable on professional balancing equipment.
I've done balance checks after Dynavib balances and other "hobby" balancers and my numbers are always higher (I can't even get .01x on my own aircraft after multiple attempts). I have had a few over the years that got into the .01x range but after hundreds of balance jobs I can assure you that .01x is generally impossible to achieve (notice my equip goes out 3 places while most only go 2 places)
What some of the manufactures say:
Unless otherwise specified by the engine or airframe manufacturer, Hartzell
recommends that the propeller be dynamically balanced to a reading of 0.2 IPS,
or less.
Most dynamic balance equipment manufacturers specify 0.15 - 0.2 ips as being an
acceptable level. McCauley Propeller Systems agrees that 0.15 - 0.2 is an acceptable
level, but our experience has shown that 0.07 ips or lower is noticeably smoother.
DANGER — 1.25 Inches Per Second (IPS) Peak Amplitude. The propeller should be removed and a static balance performed.
VERY ROUGH — 1.00 Inches Per Second (IPS) Peak Amplitude. Propeller can be dynamically balanced; however a large amount of weight will be required. A propeller static balance is recommended. Operation at this vibration level could cause damage.
ROUGH --- 0.50 Inches Per Second (IPS) Peak Amplitude. Propeller definitely requires dynamic balance. Long term operation at this vibration level could cause excessive wear.
SLIGHTLY ROUGH -- 0.25 Inches Per Second (IPS) Peak Amplitude. Dynamic balance will improve passenger comfort.
FAIR---- 0.15 Inches Per Second (IPS) Peak Amplitude. This is the maximum acceptable vibration level after dynamic balancing.
GOOD ---- 0.07 Inches Per Second (IPS) Peak Amplitude. Vibration levels below 0.07 will not be detectable by pilots or passengers.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 04-13-2019, 01:15 PM
rvbuilder2002's Avatar
Originally Posted by Walt View Post
My goal is 0.05 IPS or better when balancing, .01 is seldom obtainable on professional balancing equipment.
I agree. That is why I said a pro should be able to get close to .01.
I regularly get final values of .02 or .03 (though not meaning to imply I am a pro.... I only do 3 or 4 per year)
Opinions, information and comments are my own unless stated otherwise. They do not necessarily represent the direction/opinions of my employer.
Scott McDaniels
Van's Aircraft Engineering Prototype Shop Manager
Hubbard, Oregon
Old 04-13-2019, 04:13 PM
jask jask is offline
Default Balancer
I use the classic dynavibe and I take 5 averages before I process the numbers eliminating the high and low ips and outside angles. I process the remaining average and that works well for me.
RV-7 builder Ramona, CA.
Free prop balancing for Vans owners
(I am not in the business of prop balancing, just as a courtesy to meet other owners.)
Old 04-13-2019, 06:16 PM
Dave12 Dave12 is offline
Walt, what brand do you use? 2 accelerometers 1 front, 1 rear?
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Currently restoring a 1978 Citabria GCBC
Old 04-13-2019, 06:19 PM
Hopefully you mean .01
.1 is not horribly bad but when paying a professional do it, they should be able to get it very close to .01.
BTW, the acceleration value that is considered noticeable is .07 or higher (not .7)
Actually, by the time the weight was mounted on the spinner backing plate it was .02.
Old 04-13-2019, 06:31 PM
Walt's Avatar
MicroVib II, I only use the front accel to balance the prop, if you want to mount a rear you can but nothing you can do to really change that so it pretty much a waste of time unless you have a internal engine vibration you are trying to diagnose.
