Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
Old 11-08-2018, 11:10 AM
grubbat's Avatar
grubbat grubbat is offline
Default Another option
I just did the Uavionics tailbeacon on my -9 from Adventure Pilot. Took me about 5 minutes to install. They are currently offering a $150.00 rebate on these units ($1500.00). Gives the anonymous option when squawking 1200.
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Efficiency and Fun
Aerostar 600A
Old 11-08-2018, 11:23 AM
N941WR's Avatar
N941WR N941WR is offline
Does your news plane (congratulations, BTW) have an engine driven electrical system?
If not, you don't need to add anything, if you stay clear of the Bravo.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-08-2018, 11:32 AM
DennisRhodes DennisRhodes is offline
From your location looks like the mode C will be a requirement to fly the plane "home" unless you are on the outside of the surrounding mode C circle of ATL.
It would be about a toss up in cost if you elected to go Mode C for now and then add a ADSB unit with position GPS by 2020, if you went with say a Garmin 327 now and UAT add on later.
Being this close to 2020 and not presently having a Transponder, I would probably go ahead and elect for a ES transponder and position source and only have to install it one time. The cost will be a bit more for the ES equipment but you would not have all the "add ons" and hassle of multiple installations. Very little "used" ES equipment on the market but a ton of Mode C transponders that could be pared to a UAT to get you ADSB compliant. Especially experimental
DRRhodes
2020 VAF Supporter
RV9 N908DR
Old 11-08-2018, 01:07 PM
lr172 lr172 is offline
You should know that you can call ATC and ask for an exception to the mode C requirement for any given flight. That is an option to get you home with the new bird.
N64LR - RV-6A / IO-320, Flying as of 8/2015
N11LR - RV-10, Flying as of 12/2019
Old 11-08-2018, 01:15 PM
Jvon811's Avatar
Jvon811 Jvon811 is offline
On the subject of economical ("cheap" probably isn't a good picture to paint) Xpnder and ADS-B solutions, I bought a Garmin GTX327 (with 8710) on ebay and went with the uAvionix Echo. I also happened to go with the GRT SafeFly 2020 WAAS GPS but I'm sure the uAvionix stuff is just as good. My total came to about $2000 dollars and I really have no complaints. Being able to use Foreflight on my iPad and have the ADS-B targets with METARS and Radar is really handy too.
TL/DR, Garmin GTX327 + uAvionics Echo gets my vote.
-Justin
RV-4 N249P
O-320, Dual P-Mags, Warnke Prop, GRT Sport EX
Old 11-08-2018, 01:22 PM
Here are some estimates:
1. Buy a good used 327 mode C transponder. $400. Antenna $100. UAvionics UAT with gps for $1500 (or substitute GRT gps, same price). Total $2K.
2. Buy a Trig TT22 mode SES. $2K. Antenna $100. GRT position source $500. Total $2.6K
Either case budget another $200 for initial and subsequent (biennial) transponder checks. In option #1 you will also need an altitude encoder.
Option 1 gets use ADSB-in as well (not mandatory) but being able to display the information will involve more money.
It’s tough spending 15% of the hull value for this, but aviation isn’t cheap.
Last edited by BobTurner : 11-08-2018 at 04:05 PM. Reason: Fix - see Mel’s post below. I forgot this since I use my GRT HX as the control head.
Old 11-08-2018, 01:58 PM
Mel's Avatar
Mel Mel is offline
Either case budget another $200 for initial and subsequent (biennial) transponder checks. In either case you will need an altitude encoder.
It?s tough spending 15% of the hull value for this, but aviation isn?t cheap.
The Trig control head has the altitude encoder built in.
Mel Asberry, DAR since the last century.
EAA Flight Advisor/Tech Counselor, Friend of the RV-1
Recipient of Tony Bingelis Award and Wright Brothers Master Pilot Award
USAF Vet, High School RV-12 Project Mentor.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-08-2018, 04:29 PM
Jake14 Jake14 is offline
If cost is a major concern, you might consider:
1) ebay transponder/encoder/antenna for around $250-300 total
2) Garmin GDL82 for name-brand ABS-B with WAAS antenna, anonymity, etc. for $1795
(This unit should also qualify for the FAA $500 rebate)
https://www.aircraftspruce.com/catal...ps11-15319.php
3) My last transponder check was $126
RV-14A flying 390 hrs
Old 11-16-2018, 09:35 AM
marked marked is offline
Thanks to everyone for the information.
Does anyone have experience with the SkygaurdTWX UAT units?
This is my plan to get the plane home to for the install.
Old 11-16-2018, 11:41 AM
Shawn25854 Shawn25854 is offline
Welcome and congrats on the purchase.
I have to agree with many others here, don't go cheap. Just because the plane was inexpensive doesn't mean everything else will be. This is not a poor man's hobby. It certainly doesn't have to be expensive but if you try to go cheap it will bite you in the "wallet" later.
I'd consider the Garmin GDL-82 at $1795 with a $500 FAA rebate and a used Garmin GTX-327 for around $450. No external encoder needed and less wiring to do. You can get a TED transponder antenna from Spruce for about $35. You'd be all-in at around $1800 and have all Garmin equipment. Can't go wrong with that.
I have the GDL-82 with a 327 and it works absolutely perfect.
I know Skyguard makes a portable unit and last I heard portable units are not 2020 compliant. Make sure what you are buying if you buy used.
