Old 11-08-2018, 06:20 AM
kbalch's Avatar
kbalch kbalch is offline
Minor thread drift here, but, so long as we're talking about the wingtip lenses, how exactly should one cut them?
I'm thinking of a cutoff wheel (perhaps a little one in a Dremel), but am open to other suggestions.
Ken
RV-8 N118KB (#81125) - Sold
RV-14A N114KB (#140494) - For Sale!
RV-14A N114KB 'For Sale' page
RV-14A.com
N114KB Build Site
Old 11-08-2018, 10:48 AM
MED MED is offline
The wing tip lens material does not cut like the canopy plexiglas. It melts with a Dremel cut-off wheel or sanding drum. The best way I came up with to cut it was with a Japanese pull saw. Then, trim to the line with a sharp block plane. There must be an easier/faster way, but I couldn't find it. These lenses were a slow, tedious process to fabricate and fit and they still did not come out as well as I had hoped. I am not too thrilled with attaching them with only two screws, according to the plans, either. Good luck.
MED
140236
N435MD
Miss March 2020
Old 11-08-2018, 07:37 PM
Doug Rohrer Doug Rohrer is offline
Default Lenses
You can cut the material with tin snips, believe it or not. Then sand to final shape. The two screw fastening system works well. Never heard of one falling off.
Doug Rohrer
Bowling Green, KY
Old 11-08-2018, 08:00 PM
I used a low feed rate on a metal cutting bandsaw. I taped over the cut lines first.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-09-2018, 09:32 AM
sglynn's Avatar
sglynn sglynn is offline
Default WD40
WD-40, the oil. It will remove stuff similar to MEK but without hurting the plexiglass or the painted finish. Not as powerful as MEK but for some reason WD-40 removes glue, ink, grease, icky stuff and leaves the underlying finish alone.
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
Old 11-09-2018, 06:55 PM
kentlik's Avatar
kentlik kentlik is offline
Hardware store Kerosene will work. I have used on delicate materials...Goof off is 70% Kerosene...Check on a discarded piece to ensure it does not craze the material, shouldn't.
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
