-POSTING RULES
-Advertise in here!
Keep VAF Going
Donate methods
Point your
camera app here
to donate fast.
Old 03-05-2020, 10:47 PM
EV's RV6 EV's RV6 is offline
Default wing plugs to allow you to jack a wing up
Awhile back I had seen an ad for letting you remove your wing tie down bolts and installing a tool in that hole that would let you jack the wing up to change a tire anyone know about a tool like that?
EV
Old 03-05-2020, 11:08 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Default Jack Points
Are these what you are looking for?
Bogert Aviation (These also include an adapter that fits on the jack):
https://bogertaviation.com/products/...3a4ac23a&_ss=r
Anti-Splat Aero:
https://antisplataero.com/products/quality-jack-points (also available through ACS: https://www.aircraftspruce.com/catal...ts05-12379.php )
Carl N.
Arlington, WA (KAWO)
RV-8, 805 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflugel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 03-06-2020, 07:21 AM
Northernliving Northernliving is offline
EV
I’ve used Bogert Aviation‘s that Carl linked to with a harbor freight bottle jack (with a platform stand) and they work great.
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Project #83313 - Under Construction
Old 03-06-2020, 07:55 AM
Greg Arehart's Avatar
Greg Arehart Greg Arehart is offline
I use an 18" HF bottle jack. Drilled a 1/2" hole in the top, parallel to the stroke of the jack. Insert a ~5" piece of 3/8" threaded rod into the tiedown hole, with the other end in the hole in the bottle jack. Very stable and secure. Of course you have to properly brace the jack (there are a couple threads on here about building the jack stand).
Greg Arehart
RV-9B (Big tires) Tipup @AJZ or CYSQ
N 7965A
Old 03-06-2020, 08:54 AM
jrtens's Avatar
jrtens jrtens is offline
Be very careful using jack pads - especially with one wing and no tail stand. They have a nasty proclivity to slip off the jack and then you have a big hole in your wing. You might consider placing a piece of 2X6 wood with foam or carpet between the tie down bolt hole and jack instead.
Jon
12iS SLSA #5
Salt Lake Int'l
Old 03-06-2020, 09:27 AM
JonJay's Avatar
JonJay JonJay is offline
I would suggest you go to Vans site and read how the factory recommends jacking your RV. Your statement contradicts this and many of us who have followed Vans recommended practices for years. The few problems that I am aware of where pure negligence.
You couldn't knock my RV off the jacks if you tried.
By the way, for the OP, yes, you can buy an expensive insert, or you can do like most of us; grind down the head of a grade5 or grade8 bolt and use a proper jack adaptor with a dished out receiver. By the way, Vans used to supply a plastic insert, yes plastic. I used it for years before making my own bolts.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-06-2020, 09:42 AM
BillL BillL is offline
+1
Bill
Lord Kelvin:
I often say that when you can measure what you are speaking about,
and express it in numbers, you know something about it; but when you
cannot measure it, when you cannot express it in numbers, your knowledge
is of a meager and unsatisfactory kind.
Old 03-06-2020, 10:45 AM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
I used to use plain old carriage bolts. But I also had a plywood board around the carriage bolt with felt between the board and the wing, just in case.
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 03-06-2020, 11:27 AM
Steve Melton Steve Melton is online now
Cleveland tool makes a tie down that I use as a jack point. I never take them out.
https://www.cleavelandtool.com/colle...18378247110718
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 800+ for all
Simplicity is the art in design. I was born an airplane nut. I have no explanation for it.
My Artwork is freely given and published and cannot be patented.
www.rvplasticparts.com
Ralph Inkster Ralph Inkster is offline
I thought of carriage bolts initially but the ones in our local hardware store looked pretty crude & maybe brittle. I opted for grade 5 bolts rounded off, when they got lost my next batch were grade 8 (batch because I tend to loose them)
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
