-POSTING RULES
-Advertise in here!
Keep VAF Going
Donate methods
Point your
camera app here
to donate fast.
Old 02-04-2019, 07:08 AM
BH1166 BH1166 is offline
Default TED Transponder vs 978MHz TED
Previous owner had a NavWorx unit installed. Transponder uses a Delta Pop and there is a TED on the belly as well. How would I determine if the correct TED is installed e.g. the 978MHz version ? I am thinking the length of the antenna may make it a transponder vs 978MHz changing the bandwidth, but just a guess. Would like to use it if possible for the EchoUAt unit I am getting ready to install. The TED is mounted in the tail cone...delta pop just behind the firewall.
Butch
RV6A Purchased N72TX
Old 02-04-2019, 08:32 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
A transponder antenna will be about 1/4" shorter (2.659" vs 2.408") than a 978MHz antenna, so shorter but not by much.
Even though others here will swear it is a disaster waiting to happen, for our application you can use it with no problem. Now, if you are in a controlled laboratory environment with sensitive measuring equipment then you will notice an improvement with an antenna cut specifically to 978Mhz instead of 1060Mhz. But with a good installation you really won't see a difference in operations.
FWIW I have been using a regular transponder antenna for my 978UAT receiver since 2013 and get the same reception as others, flying with specifically designed ADS-B antennas. At the end it comes down to a decision based on costs, ease of installation and looks more than anything else.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 02-04-2019, 08:37 AM
10builder's Avatar
10builder 10builder is offline
TED transponder antenna length (base to tip) is 2 7/16” long whereas the TED ADSB antenna length (base to tip) is 2 21/32” long which is a difference of about 7/32 if my math is right. The antenna specs can be found on the ACS site.
....or basically what Galin said!
Brian S.
Arrington, TN
SPA Panther N87XP
RV-10 N104BS (Sold)
2020 VAF donation cheerfully submitted!
Old 02-04-2019, 09:09 AM
Thanks Galin and Brian for your response. I have pulled the specs for both from ACS. I just pulled out the documentation on the NAVWORX and it says use either a RAMI AV11 or RAMI AV74. YEAH ME ! No sliding down the tail cone to replace. I willl measure it to be sure. Again thanks!
Butch
