wirejock
How many sets of holes did you drill and how far apart? How tall are you?
I'm 5'6" 30" inseam (short) so I figure I need the pedals closer than most. But where to drill?
I was hoping the center block and outboard blocks had the same hole dimension so I could 1/2 the distance and drill a few sets. That way every hole could be used for either side of the block.
That won't work because the center block holes are closer together. Manual calls for 2D seperation between hole edges so I thought maybe 1" apart till I get to a hole distance interference. Problem is without sitting in the cockpit, I have no idea if the pedal location will be all the way aft, mid point or forward.
What say you 7 drivers of similar height (if any exist)?
And no short jokes! I loved it when big guy couldn't squeeze into the race car and I would climb right in. They always wanted me to do the exit test because I could beat the clock no problem.
