I sent the following info to the G3 experts but the Forum is also a good place for answers:
I have a GMA 245 Bluetooth audio panel in my RV-8 and use it frequently to pair with my Garmin Virb Ultra 30 camera. This combination works great with crystal clear audio. When not using the camera I frequently listen to music while flying. During my panel upgrade I installed a small audio jack to plug into my IPhone to save power from the drain of the battery while using bluetooth.
The music input jack worked perfectly until the first time I used Bluetooth. Now it seems to be stuck in Bluetooth mode and I can’t get any music through the audio jack. I did see that the manual says it can use only one external music input at a time so that makes sense that BT is preventing me from using the audio jack.
How do I turn off/disable Bluetooth on the GMA 245 so my music jack will work?
Oly Olson
Oly Olson
