Old 01-30-2019, 04:25 PM
kbalch's Avatar
kbalch kbalch is offline
Done!!
I was able to wedge my smallest ¼" open-end wrench on each of the forward nuts and then nudge the respective bolt head about a 1/32 of a turn at a time with a socket extended down between the fuel lines aft of the selector.
What a bear!!!!
Ken
RV-8 N118KB (#81125) - Sold
RV-14A N114KB (#140494) - For Sale!
RV-14A N114KB 'For Sale' page
RV-14A.com
N114KB Build Site
Old 01-30-2019, 04:26 PM
kbalch's Avatar
Originally Posted by MED View Post
If you hated the cable clamps, just wait until you run the wiring to the sticks . . .
Already dreading this for sure...
Ken
RV-14A.com
N114KB Build Site
Old 01-30-2019, 10:34 PM
Lizard Lips Lizard Lips is offline
Jeeeez! I thought it was just me and my inexperience giving me so much trouble with this. I spent the entire afternoon Sunday getting one rear bolt started. Still working on the other three! Finally gave up from sheer exhaustion.
Joe Reaves
Longview, TX
2019 Dues paid.
RV-14A Empennage complete, QB fuselage and aft section joined
Arian Lightning LS-1 Flying
Old 01-31-2019, 06:22 AM
kbalch's Avatar
Nope, it’s not you. There are some tasks that are just awkward and miserable no matter how much experience (or how many specialized tools) one has.
Stick with it - you’ll get it done eventually.
Ken
RV-14A.com
N114KB Build Site
Old 01-31-2019, 09:02 AM
n982sx n982sx is offline
I tell people, as an airplane or a large sub assembly of it nears completion, you will inevitably find some step that requires the hands of a child and the strength of 10 men.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 01-31-2019, 02:53 PM
Arablenz Arablenz is offline
I like that saying Bob. So true I am finding.
Old 02-03-2019, 04:04 PM
Jake14 Jake14 is offline
I never anticipated this, but one of the most useful tools for assembling stuff like this turned out to be my 1/4 in drive cordless electric ratchet...
https://www.amazon.com/ACDelco-ARW80.../dp/B00X9B8QUI
I used the 1/4" hex drive adapter and could nest any number of extensions to get into tight spots, with the main advantage being that you don't need any space to swing the ratchet...just push the button...but go slow to avoid over-torqueing
I was able to tighten bolts through the firewall by holding the bolt on the firewall with a wrench and reaching around under the panel with a 2-3ft extension on the ratchet...
RV-14A flying 350 hrs
Old 02-20-2019, 07:45 PM
iamtheari iamtheari is offline
With help, I was finally able to get the forward two nuts started. Now, how does one torque them?
I think I will pick up one of those electric ratchets, although I'm not sure there's room for it in this space.
Can anyone tell me why it wouldn't be possible, if you knew about this battle ahead of time, to install these sleeves and clamps earlier, such as on page 28-08 just before the F-01403 bulkhead assembly is installed on the firewall/tunnel assembly? As someone who installed the rudder cables backward back on page 10-21 and had to reverse them before installing the guides in the tunnel in section 33 (which I fortunately noticed before putting any of these clamps in place!), I would rather run the rudder cables through a completed empennage 1,000 times before installing the sleeves after the F-01403 bulkhead again.
Old 02-20-2019, 08:35 PM
JDA_BTR JDA_BTR is offline
I too spent a whole day getting this done. I'm certain it could be done with care earlier in the build.
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 02-26-2019, 11:32 AM
markelliott markelliott is offline
Is there any reason a person can't reverse the bolt and have the nut and washer on the clamp side? I just put an extra washer under the bolt head to protect the rib - the length on the bolt was still ok with 3 threads outside the locknut. Makes it not a bad job.
