Old 01-30-2019, 01:21 PM
kbalch's Avatar
kbalch kbalch is offline
Originally Posted by Bavafa View Post
Looks like you built a 8 which I assume tighter space than 14, it is tight but don't recall to be super bad.
From the perspective of so many years on (my -8 first flew almost 17 (!) years ago), I don't recall any one spot this inaccessible. Possibly down side the gear towers...
Ken
RV-8 N118KB (#81125) - Sold
RV-14A N114KB (#140494) - For Sale!
RV-14A N114KB 'For Sale' page
RV-14A.com
N114KB Build Site
Old 01-30-2019, 01:24 PM
kbalch's Avatar
Originally Posted by MS19087 View Post
I am months away from this step . . . however would this be an area where a nut plate could be employed? It would make the job at least half-way easier . . . not looking at plans so don't know if this is viable.
With enough foresight (or, you know, an actual useful change to the plans!), this could be done.
From where I am now, it might be possible to run the bolt into an unriveted nutplate and let the "ears" stop it from rotating as the bolt draws tight. Never to be removed, of course! Might have to resort to this...
Ken
RV-14A.com
N114KB Build Site
Old 01-30-2019, 01:26 PM
kbalch's Avatar
Originally Posted by drtgraves View Post
I'm 4 sections behind you.. Is there any reason why the bolts cannot be put in from the outboard side into the tunnel? If not I have some grand kids with little hands to loan out
I think it'd be just as difficult to get a wrench on the bolt head in that location as the nut.
I might take you up on those grandkids!
Ken
RV-14A.com
N114KB Build Site
Old 01-30-2019, 01:34 PM
PatrickN PatrickN is offline
I'm also getting close to that section. Is there any reason the sleeves cannot be installed before installing the fuel valve and lines? I know the rudder cables need to pass through flanges on the baggage floor, but other than that, I haven't found a reason I can't route the rudder cables earlier.
RV-14 #140469
Empennage Kit: Complete
Fuselage Kit: Complete
Finishing Kit: In Progress
Old 01-30-2019, 01:39 PM
kbalch's Avatar
Nope. Those baggage floor snap bushings are the only impediment to doing the sleeves prior to the fuel system. Just do the baggage floors first and you'll be good to go. Wish I'd done it that way.
Ken
RV-14A.com
N114KB Build Site
Old 01-30-2019, 01:47 PM
Excellent! Thanks for the info. :-)
RV-14 #140469
Old 01-30-2019, 01:50 PM
kbalch's Avatar
No problem at all. To clarify: do sections 32, 33, & 31 in that order and you should be all set.
You could also do the section 31 fuel line tasks after the rudder cables and before the brake lines.
Ken
RV-14A.com
N114KB Build Site
Old 01-30-2019, 02:02 PM
azflyer21 azflyer21 is offline
In my infinite wisdom I installed those cables and clamps (took way too long) before the baggage floors. Sooo, I got to install the clamps twice.
Kevin Lippert
RV-14A N1402 Flying 03-2020
Phase 1 Complete 07-12-2020
Build Log
Zenith 750 completed 2016 -
Sold
Old 01-30-2019, 03:18 PM
MED MED is offline
If you hated the cable clamps, just wait until you run the wiring to the sticks . . .
MED
140236
N435MD
Miss March 2020
Old 01-30-2019, 03:40 PM
mturnerb mturnerb is offline
My most important trick here was to use safety wire to close the adel clamps over the sleeves. Unfortunately I wasn't able to get cutters on them after installation so I just left the wire in place.
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
