Old 01-29-2019, 12:42 AM
Mikeandmaz Mikeandmaz is offline
Default Another Nutplate question
I?m working my way through the aft fuselage and yesterday countersunk the nutplate attachment holes in the Battery Angles. Reading ahead in the plans I have, I can?t see any use for these nutplates . I?m sure there is, probably in a following kit, but just interested in what they are for.
Waiting for enlightenment!
Mike
Empennage arrived
VS completed
Rudder completed
HS completed
Elevators completed
Quick Build wings, fuselage and finish kit deliverd
#140425
Donation paid 2019
Old 01-29-2019, 06:56 AM
mulde35d's Avatar
mulde35d mulde35d is offline
Default Nutplates
I believe you are talking about the holes that get used in Section 36 while installing the Elevator system push/pull tubes and bellcrank.
Jon
http://www.mykitlog.com/mulde35d
RV-14A Sold
RV-10 Research In Progress
Old 01-29-2019, 09:00 AM
RandyAB RandyAB is offline
There are nutplates there for the master solenoid too.
______________________
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
Old 01-29-2019, 12:54 PM
JTJones's Avatar
JTJones JTJones is offline
Also autopilot pitch servo (and yaw servo if you choose). Those plans pages sections (56/57/58, depending on brand used) will come with the installation kit. And forward of that there is room for some avionics - transponder for instance.
Jeffrey T Jones
RV-14 N588TJ Completed
First Flight July 10, 2018
Flight testing completed August 14, 2018
2020 VAF dues paid plus beer money😜
Old 01-29-2019, 08:12 PM
Jake14 Jake14 is offline
They're called battery angles because they are the same part nos. used to support the battery in the RV-10. The RV-14 battery is on the firewall as are the solenoids. Those brackets also hold the elevator tube bellcrank and the pitch servo.
RV-14A flying 390 hrs
Old 01-30-2019, 12:24 PM
Thanks for the replies, I?ll look forward to using them in a few years time.
Empennage arrived
VS completed
Rudder completed
HS completed
Elevators completed
#140425
Donation paid 2019
