Old 01-21-2019, 12:17 PM
iamtheari iamtheari is offline
Default Page 35-16 - drilling WD-619 and WD-618-1 Canopy Release Assembly
I have assembled the release mechanism as shown on page 35-15 figure 3. I am ready to drill the release tube and crank, but I am concerned about the way they fit together. Specifically, page 35-16 figure 1 shows the WD-619 inner tube flush with the WD-618-1 outer tube. Mine is about 1/8" back inside the outer tube, as if the inner tube is not long enough. If I drill 0.313" back as the plans show, and drill #12 (0.189") per the plans, my edge distance on the inner tube will be:
+ 0.313 center
- 0.095 hole radius
- 0.125 backspacing
.093 edge distance
This seems pretty small. Thoughts?
Old 01-22-2019, 02:30 PM
bschweinberg bschweinberg is offline
Default Canopy Release Assembly
[quote=iamtheari;1318532]Specifically, page 35-16 figure 1 shows the WD-619 inner tube flush with the WD-618-1 outer tube. Mine is about 1/8" back inside the outer tube
QUOTE]
I noticed the same thing and chose to drill the hole a little further in, about 1/8 inch
Bill Schweinberg
West Chester, OH
N2814X Reserved
RV-14A Started Nov 2013
Builder #140100
Empennage/Tail Cone DONE! (95%)
Wings In Progress (90%)
Fuselage In Progress (75%)
Finish Not Started
http://www.mykitlog.com/bschweinberg (not up-to-date)
=VAF= 2019 Dues Paid
