Old 01-03-2019, 07:14 AM
mturnerb mturnerb is offline
Returning to the OP's question - I had to get a bigger piece of fire sleeve than what was provided in the kit to do the outer "wrap". I had some laying around fortunately.
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
Old 01-03-2019, 07:15 AM
Brantel's Avatar
Brantel Brantel is offline
Like others have said, for single cables use the steel multi piece eyeball pass through?s mentioned above. Harder to install but worth it! The single hole aluminum ones are junk!
As for wires/bundles you can get all the parts to build them yourself way cheaper if you buy the parts to make it individually. You can buy the stainless flange from hardware stores or amazon. Look for stainless closet rod holders. They are less than $10 for a pair of them.
I did not do this on my 7 but will on my 10!
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Wings
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 01-03-2019, 07:54 AM
dwranda dwranda is offline
Default A thread I found
http://www.vansairforce.com/communit...d.php?t=156470
9A in progress
Working on Finish kit!!
Mattituck TMXIO-360 red gold
Dues paid Jan 2020
Old 01-03-2019, 11:28 AM
Default which size?
I see on Amazon there are different sizes of these stainless rod holders. Is the 1 inch diameter big enough if using 2 of them? I think the other is 1.3 inches inside diameter. Is this like anything else where bigger is better?
9A in progress
Dues paid Jan 2020
Old 01-03-2019, 11:45 AM
Arablenz Arablenz is offline
I had the same concerns about the firewall sleeves and had it confirmed by Vans that we use the FAE102-11x1 ft sleeve they send with firewall forward kit. Apparantly we make that fit for both the inner and outer pass through by splitting that sleeve.
Old 01-03-2019, 11:53 AM
Default How many
I have a large one and a small one. The large one was required to pass the EFII harness connectors through. I separated the EGT/CHT wires to the small one, as was recommended by Garmin.
I now have a System 32 EFII harness which includes bulkhead connectors so I really did not require the large pass through, 2-1" pass throughs would have been sufficient.
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 01-03-2019, 12:36 PM
rv7charlie rv7charlie is online now
1st, decide whether you need to pull assembled connectors or control cables through the hole(s). If yes, then the connectors/cable ends will define hole size. Bundle up everything you need to run through each hole, wrap the firesleeve, and measure.
Charlie
Old 02-05-2019, 02:42 PM
Stockmanreef Stockmanreef is offline
I am debating adding a few extra pass throughs. An A&P suggested that all the cables go through individual eyeball fittings, then the wires can run through the two original pass thru locations. Anybody do this? If so, then where did you place the eyeball fittings.
I did purchase pass through kits from ACS to bundle and protect the wires after coming through the firewall.
Unfortunately, I just finished insulating the firewall, so putting in eyeball fittings might be a nightmare. I have the insulation and the engine mount in place. The though of all the shavings from drilling make me sick to think about cleaning up.
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
Old 02-06-2019, 05:31 AM
DakotaHawk's Avatar
DakotaHawk DakotaHawk is offline
Originally Posted by Stockmanreef View Post
... so putting in eyeball fittings might be a nightmare. I have the insulation and the engine mount in place. The though of all the shavings from drilling make me sick to think about cleaning up.
I just purchased this hydraulic punch set from Amazon Aircraft Stuff. Tool quality is basic HF/Chinese but it makes an easy and clean punch thru the SS firewall.
https://www.amazon.com/OrangeA-Hydra...ydraulic+punch
_______________________________
Scott "Grumpy" Stewart
RV-7 N957RV (First Flight on Dec 18, 2009)
RV-14 N144P (Empennage complete, wings almost complete, fuselage almost complete)
#866 on the Van's RV-7 hobbs
#6563 on Van's generic hobbs
Arlington, WA
Old 02-07-2019, 05:41 PM
Any thoughts about using something like the aluminum bulkhead in the link below as a pass thru for the cable, if it were made out of stainless steel? It would not allow for rotation like an eyeball fitting, but it would require a much smaller hole in the firewall.
https://www.jegs.com/i/Earls/361/983210/10002/-1
Ken Stockman
Midland, MI
N73XP
