Old 11-07-2018, 01:00 PM
DanH's Avatar
DanH DanH is offline
Originally Posted by KeithB View Post
It looks like there are differences between the original (Lycoming) and the clone (Superior). The XP400 is stroked an additional 0.25?. Whether or not that is material is beyond my pay grade.
Yeah, that's a Superior-only crank, currently out of production. It was used in the 382 and 400.
I doubt additional stroke changes the CHT vs advance relationship in any meaningful way.
Dan Horton
RV-8 SS
Barrett IO-390
Old 11-08-2018, 03:27 PM
Nova RV Nova RV is offline
These were my numbers yesterday at 2500 feet and OAT 61F running 24" and 2450rpm. IO390 and 2- PMAGS timed at 20 degrees.
Full rich oil temp 189
#1 235
#2 196
#3 231
#4 233
leaned to about 20 degrees rich of max EGT oil temp 191
#1 259
#2 220
#3 252
#4 251
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
Old 11-08-2018, 04:56 PM
Carl Froehlich's Avatar
Am I wrong or does the data showing excessively low CHTs scream of too much cooling drag? Is this opportunity to clean up the RV-14 cowl inlet/outlet to gain a little speed?
Old 11-09-2018, 06:00 AM
Carl,
Yes they do seem to be very low. I started this thread because of it and also because I noticed there were no posts that I could find about high CHT issues in a 14. Based on the posts here it seems to not be an issue but I agree mine seem very low and I wanted some other data than mine before I start pulling things apart to run some tests. My setup is the stock CHT thermocouples that come in the Lycoming kit from Garmin, I have the correct thermocouple wire from the sensors to the GEA24 pins and no dissimilar metals connectors or solder in between. When I was assembling, I did some tests using the stock sensors and different wire from the sensor to the GEA24 unit and did get some interesting errors vs. OAT when I used different (non thermocouple) wire.
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
Old 11-09-2018, 07:12 AM
bkervaski's Avatar
At 85-95deg F (Alabama Humidity) between 4500-5500 mine are consistently 340-360 at 85%, 320-330 at 75% but I generally lean out a bit to bring them back up to 340-360. Oil temps started at around 225 but as the hours went by the settled to around 185.
The manual states:
For maximum service life, the Cylinder Head Temperature (CHT) must be maintained below 435ºF (224ºC) during performance cruise operation and below 400ºF (205ºC) for economy cruise powers.
But doesn't really give an optimal operating range.
For oil:
The maximum permissible oil temperature is 235°F. (113°C.). For maximum engine life, maintain desired oil temperature is 180°F (82.22°C).
As a noob, I'm always looking for advice on how to manage my engine.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 12-03-2018, 11:33 AM
Bavafa Bavafa is online now
Just wondering what folks are getting for their top speed on their 14/14A.
My numbers so far has been encouraging... it has been cooler weather here so I lucked out. During the engine break-in, the two hours of full power, I was seeing 340-350 CHT and 204 oil temp. Yesterday, on my 6th hour of flight already seeing lower oil temp and CHT.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 02-07-2019, 06:45 AM
Just to update this for anyone collecting data, yesterday I did a boiling water test on all of the CHT probes and found #2 to be reading 20 degrees low (10% error) and the rest read 209-215 degrees (cycling around 212). This low #2 seems to corroborate the data from earlier with #2 always being lower. I also pulled all of the spark plugs and #2 were no different looking from the others so I'm sure it's firing correctly and that the one CHT probe is just off.
As to why the CHT numbers seem low from some others, no idea really. One difference from stock is that I have a Vetterman exhaust (4 into 2) which could run cooler or the exhaust opening at the rear of the cowling is larger than stock because of the extra cut outs to accommodate the dual pipes. One other difference is that I had the exhaust ceramic coated which could make a difference temp wise but I really have no way to claim this without any before/after data.
One interesting note is that my friend has a nearly identical setup in his 14A (Thunderbolt, Whirlwind prop and a ceramic coated exhaust) but his exhaust is stock and his CHT numbers are 30+ degrees higher than mine.
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
Old 02-07-2019, 08:26 AM
rvbuilder2002's Avatar
That explains a lot.
I haven't seen a Vetterman installation on a 14 but if additional openings are added to the cowl, an increase in cooling flow would be expected.
That alone might make a Vetterman exhaust not a good choice unless the builder is willing to do other experimenting to modify the stock cooling exit.
Opinions, information and comments are my own unless stated otherwise. They do not necessarily represent the direction/opinions of my employer.
Scott McDaniels
Van's Aircraft Engineering Prototype Shop Manager
Hubbard, Oregon
Old 02-07-2019, 10:30 AM
KeithB's Avatar
KeithB KeithB is offline
Verterman 4 in 2 on Superior XP400 - the cutouts don?t have to be very dramatic. However, obviously the entire tunnel is outflow.
I have also since added small deflector extensions trimmed almost parallel to the airflow.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, 24th in the air, >600 hrs
XP-400 Aero Sport Power, replaced with Lyc Thunderbolt 390
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 9/2019
Old 02-07-2019, 10:53 AM
Scott, I'm not questioning your analysis but how are lower CHTs bad unless they are so low the cylinders can't "expand" properly and not allow it to break in properly or cause increased wear? Lower temps within reason was always told to me as being a good or better thing.
My cut outs are similar to Keith's although slightly larger.
Thanks!
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
