Old 01-15-2019, 10:39 PM
wjb's Avatar
wjb wjb is offline
I've been hand drilling the countersinks in my cowl using some carbide-burr countersink bits with great results. Go slow, and check often. All have come out just right.
Bill Bencze
N430WB RV-7 #74152 @ KHAF, tip-up; IO-360-M1B; Hartzell CS. !! Phase 1 !!
2357 hrs over 8.5 years to get to flying. Log at: http://rv7.wbencze.com
VAF 2020 donation happily made
Old 01-16-2019, 11:23 AM
bk1bennett's Avatar
bk1bennett bk1bennett is offline
I used a drill press and my calibrated eyeball.
Latest Annual Donation Date: 06 August 2020
RV-14A Empennage Kit #140396
Old 01-16-2019, 05:05 PM
RV10Pilot RV10Pilot is offline
How about something like this
Old 01-16-2019, 05:34 PM
scard's Avatar
scard scard is offline
Yep. I call it kamikaze counter sinking or dimpling. Free hand can liberate you from the cage . Just be darn sure you can meet your quality assurance expectations before ruining a part. The other such operation is a dimple die in the rivet gun and it's companion in a backing buck. Do you feel lucky? <smily face fully implied!>
Once you get over the pressures, angles, and all the ways this could go wrong, you'll be moving right along without so much jig analysis. I know a Boeing production engineer would be squirming in his seat, but we aren't build a space shuttle here.
Scott Card
CQ Headset by Card Machine Works
CMW E-Lift
RV-9A N4822C flying 2200+hrs. / Cedar Park, TX
Old 01-16-2019, 07:13 PM
ColoCardinal's Avatar
ColoCardinal ColoCardinal is offline
Default countersink
. . or you could replace them with an internal stop: https://www.flyboyaccessories.com/In...top-p/2102.htm
Carl - - Morrison, CO
N16CB RV7A
Airworthiness cert issued 12/24
best X-mas present I could have hoped for!
paid 'til 10-19
Old 01-17-2019, 12:00 AM
control control is offline
I have had great success using the cutter without cage in a small battery powered screwdriver. Easiet than going full manual as I can focus on keeping the angle right while the machine works at a slow seady pace.
RV-14 kit #140138
Flight testing
Http://magnusrv.blogspot.se
Old 01-19-2019, 02:56 PM
RonS RonS is offline
Hit this same issue last week. I picked up a paint cutter arbor from Spruce which is threaded to accept my CS cutter and mounted it in the drill press. https://www.aircraftspruce.com/catal...utterarbor.php
Ron Slosberg
Roswell, GA
RV-14A -- Finish Kit
Build Log: https://ronslosberg.com
